Question about Ovens
Whirlpool oven 465 self cleaning
Can you tell me how to change the temperature from C to F it changed to C and I don't know how.
4 Suggested Answers
SOURCE: Whirlpool self cleaning oven, Super capacity 465, door will not close
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
Posted on Dec 02, 2008
rylee_smith
  • 8619 Answers
SOURCE: whirlpool self cleaning oven problem
Hi
Thanks for using FixYa. This error means that you’ll need to check the door latch/switch and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
SOURCE: whirlpool self cleaning oven 465 capacity model oven doesn't get
GAS OVEN GETS WARM BUT NOT HOT
Posted on Aug 02, 2010
The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
Don't have a appliance booklet for my Whirlpool Model 465 Super Capacity oven - need to know how to clean please
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Jan 06, 2011 | Ovens
OVEN TURNING OFF BY ITSELF. I THINK THE CODE ON IT IS SAYING F2
Hi!
The F2 code means Oven Temperature Too High. When this code is present do the following:
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 02, 2010 | Whirlpool SB160PEE Gas Single Oven
Whirlpool self cleaning oven problem
Hi
Thanks
Rylee
Jul 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The oven door won't open, and there is still food in it. We have a Whirlpool Super Capacity 465 Model, amd need assistance immediately.
Hello. It is possible that the oven accidentally got turned to the self-clean function. Check to see. If it is set to self-clean, the door lock activated. In order to unlock the oven has to be taken off of self-clean and then it has to cool down to room temperature before it will unlock. Joe
Apr 04, 2010 | Ovens
Jul 03, 2008 | Ovens
Whirlpool Accubake oven super capacity series 465
In an attempt to self clean my oven, I pushed the auto clean button and then pressed start. Instead, nothing happened, but now have a message on the panel reading E1on the left side of panel and -F5- on the right side of panel. I am unable to clear it or operate the oven now.
Mar 16, 2008 | Whirlpool SB160PEE Gas Single Oven
ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
HOW DO YOU CLEAN SELF CLEANING OVEN SUPER CAPICITY 465
Sep 23, 2007 | Ovens
Ovens Logo
95 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
