Question about Canon imageRUNNER 2870 Copier
Canon ir4570 ir3570 ir2870 ir2270 service manual
    New Friend:
  • 19 Answers
Hello friend, you can find the canon ir4570 ir3570 ir2870 ir2270 service manual in below link:
Canon service manual:
http://goo.gl/GDAzQQ
Thanks
Posted on Dec 02, 2014
redzventures
  • 149 Answers
SOURCE: I AM LOOKING FOR SOMEONE TO SERVICE A CANON
We can provide service if your copier is in Brighton, UK. What is the problem?
Posted on Aug 04, 2009
  • 108 Answers
SOURCE: How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Posted on Nov 25, 2009
Testimonial: "Thanks, Can you please advice how do i print network setup page from this printer [Cannon ir3570]"
babaprithi
  • 372 Answers
SOURCE: canon ir2270 ir2870 error
whats the error dear
Posted on Jun 13, 2011
roytardio
  • 106 Answers
SOURCE: canon ir2270 ir2870 error problam
what is the error of your copier the one you ask?
avpmedia
SOURCE: im looking for service manual for canon ir2870
Here: http://www.smpcshop.com/Canon-iR2230-iR2270-iR2870-iR3530-iR3570-iR4570-Service-Manual.html
Posted on Apr 14, 2013
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2002n please
Description
The main thermistor reading does not reach 40C 14 sec after the fixing heater goes ON (fixing low temperature error)
Remedy
1) Wiring Is the connection of the connector (CN8) on the power supply PCB and the connector (J103) on the DC controller PCB and the wiring to the fixing assembly normal? NO : Correct the connection and wiring. 2) Fixing assembly Try replacing the fixing assembly. Is the fault corrected? YES : End. 3) Power supply PCB, DC controller PCB Try repacking the power supply PCB. Is the fault corrected? YES : End. NO : Replace the DC controller PCB. 4) Error With the power switch ON, clear E000 through E004; then, turn off and then on the power switch.
Aug 05, 2015 | Canon Office Equipment & Supplies
How to fix the Canon Image Class Printer 4750 error code e001-0000
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
Im looking for service manual for canon ir2870 copier
Dec 20, 2010 | Canon Office Equipment & Supplies
Paper jams at heater section in ir4570 in A4, A4R is OK for some time. replaced film but problem not solved. require original fixing film for ir4570 part number
Depending on your voltage requirements; Fixing Film Unit FM2-1793-010 120V FM2-1812-010 230V FM2-1792-020 100V These numbers fit iR4570 and iR3570.
May 21, 2009 | Canon Office Equipment & Supplies
SERVICE MANUAL FOR CANON IR3570
Hello friend, I had downloaded a Good canon iR3570 service manual from below link:
Canon iR 3570 2270 2870 4570 service manual:
http://goo.gl/gyD5Al
Good luck on repairs.
May 02, 2008 | Televison & Video
Canon imageRUNNER 2870 Copier Logo
277 people viewed this question
old marine
old marine
