Question about Black & Decker Black and Decker Mm575 18" Mulching Lawn Hog Electric Lawn Mower
Lawnmower dead Stopped working. Completely dead. Is it the motor? Or motor brushes? Can we check easliy
OK it is an "electric mower"!!! Why the hell would it have a gas tank?!? Your answer was no help for this person or anyone else.
Posted on Jul 20, 2015
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 64 Answers
Is the gas tank is empty. Old gas can also lead to problems starting, There is a product you can add for old gas issues see your DIY or hardware store this happens often if you have last season's gas in your mower, drain your fuel tank and fill with fresh gas. some other thoughts might be Loose, Dirty or Disconnected Spark Plug Check it out, clean off debris, re-connect and tighten. Dirty Air Filter Clean or replace. Fuel Not Reaching the Engine Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Posted on Apr 12, 2014
Bosch rs5 brushes how to replace them
most small wattage electrical motor brushes are held in by a plastic plug with a screw driver slot in the face in the side of the motor casing
with the power disconnected from the wall
remove those plugs and pull out the spring and brush
insert the new brushes
Jun 26, 2017 | Bosch Saws
My electric lawnmower starts, but has a rumbling sound and the blade doesn't turn.
Rick the rumbling sound is the brushes. They need to be replaced. Dont try and use it or you will completely damage the motor.
Sep 18, 2013 | Electric Lawn Mower
I have a KitchenAid mixer Model K5SS, Ser #W83808959. The motor stopped running and in checking the brushes, I found they are are both stuck in the brush holders. I suspect this is the reason the motor...
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
You may have to remove the Motor Housing and use a small screwdiver
to completely remove the brushes or all portions of them if they are broken.
Jul 30, 2011 | KitchenAid K45SS Classic Stand Mixer
Roller brush on Kenmore model: 116.31199100 won't turn
Refer to Larryclare1's solution at http://www.fixya.com/support/t1095798-kenmore_model_116_powermate_jr_stopped It worked great for me. Replace the belt, which you can get at Sears Parts store/online and clean out the hair as per Larryclare's instructions.
Feb 27, 2010 | Kenmore Vacuums
The motor stopped and I cannot get it working again. I ws using it and then it went dead. nothingfunctions. the motor will nt even make a noise.
I would first check that the motor brushes aren't worn out. They are held behind the black blastic caps on either side of the mixer head. These caps unscrew and the motor brushes are held in with a spring. Note the direction they go in, they are keyed and will only work when put in the right way. Use a torch to check. There is a picture of a new brush here: http://kitchenaidmixerspares.co.uk/Home/tabid/36/ProductID/88/Default.aspx
Jan 23, 2010 | Food Mixers
Fan stopped working. Could it be the relay. If
I remember those winters living North of you in MB.-50 some days...Winterpeg...
I will ask my tech about the relay but I would suspect the blower motor brushes. Check your power on several speed settings. My Camry had a resistor set up on the fan housing where one speed stopped working one one speed. Upon dismantling under dash I discovered one of several resistors on the fan housing was shot which caused that speed setting alone to fail. I couldn't buy it separately at the time so I found one in a wrecker. If all speeds are dead check your fuse and suspect worn brushes on the motor.
If you can bump the housing and hear the fan start and stop that's another indication that its likely brushes.If your bearing is worn and you can hear the fan start and stop and wobble when you hit a bump, again a symptom of motor problem versus switch or relay. Not sure if you can buy brushes only, but if you are really handy you can sometimes rebuild the blower if the brushes are failed. Given your prolonged used in winter your blower likely has more wear than one in a more moderate climate so I would look there first, under dash, knee level near the glove box.Post back and I'll talk with my tech today.
Dec 27, 2009 | 1999 Lexus RX 300
Super Sawzall 6527 just stopped working. I did an
could be a couple things, unplug tool and look at the pins on both the cord and the pin housing to make sure none pushed back, next remove handle half and remote electronic and look for a loose flag terminal at the brush holder, look for loose wires on the switch, (give a gentle tug) and remove the brushes and look for unusual wear patterns and possibly a burnt brush spring. Let me know if you need more help.
Nov 22, 2009 | Milwaukee Tool Saws
2004 Outback Driver's Seat motor dead
Try swapping motors not brushes,maybe the motors are the same just in diffrent positions,it wouldnt be cost effective to have diffrent motors for the same job just diffrent positions,im tipping they will be the same pull seat out or lookcarefully in the car to see
Sep 20, 2009 | 2004 Subaru Outback
Electric motor on Qualcast Power Trak 4000 not working. It will not trun the blade. There is electricity going to the motor at the connection point and at the brushes on top of the motor. There is no sign...
I'd first check the brushes for wear and dirt buildup. If worn badky, replace -- otherwise clean, replace, try motor. I doubt the motor is shot unless you've really been abusing it.
May 08, 2009 | Garden
MM875 electric lawnmower
check motor if armature are not broken & see if the rectifier not burnt. rectifier works from ac & convert it to dc to run the motor.
if you need diagram for parts see toolpartsdirect.com
Aug 27, 2007 | Black & Decker 19" Electric Lawnhog...
Black & Decker Black and Decker Mm575 18" Mulching Lawn Hog Electric Lawn Mower Logo
160 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
