Question about Kyocera TASKalfa 180 Copier
Error c6000 When running the machine I want a solution for 6000
    New Friend:
  • 78 Answers
Fusing unit needs to be replaced.
Posted on Apr 16, 2014
How do i fix the error code 6000 in kyocera 3060?
C6000 : Fuser heater break.
Fuser thermistor 1 detected less than
40°C/104°F for 10 s during warm-up and ready in.
Defective fuser heater M or S.
-Replace the fuser heater M or S.
Installation defectiveness on fuser thermistor 1.
-Check the mounting state of the fuser thermistor 1. If any problem is found, repair it.
Defective fuser thermostat.
-Replace the fuser thermostat.
Defective PWB.
-Replace the power source PWB or engine PWB and check for correct operation.
After parts replacement (fusing unit), you need to clear the fuser error code by going in the tech mode (10871087) and then U163.
Dec 19, 2015 | Kyocera Office Equipment & Supplies
Hello ,, I have Ricoh c 6000 and I have problems with functional with copier ,, can help anybody
the purpose of this site is to help you. So, post the image/error and we can help you, so everyone with that problem can see the solution
Nov 20, 2014 | Ricoh Aficio MP-C6000
Kyocera eroor code c-6000
Works with ERROR C6000, C6300, C6400
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on....
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
May 04, 2014 | Kyocera Mita 2 Pack Km 2020 2035 2050...
Casio SE-S6000 SE-C6000
Hii
My dearsI i have casing prob of Error E015 check R/J for Casio se-c 6000
Pleas help me if some body know tha.
Think.
Feb 08, 2014 | Computers & Internet
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
What do you mean by error c6000 in KM4050?
Error code c-6000 means fuser error. It would be best to replace the fuser unit as a complete assembly, but sometimes just the thermostat can be replaced, which would be cheaper. Either way, an authorized Kyocera dealer should have these parts.
Nov 12, 2009 | Kyocera Copystar CS-1820 Black and White...
Identification of error codes
C0000 Main motor
c6000 scanner/lamp
C5000 fuser
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 19, 2009 | Minolta EP1030/1030F CS/PRO Copier
Error C6000 is showing, can you tell me if I can fix myself or call for service.
In some cases you can reset the C 6000 - when is a false error.
try this:
1. Go to Menu/System and browse till you see
"Service".
press and hold: # START ENTER
The "Service" will go away and browse to "Maintenance".
2. Press ENTER to go in maintenace mode - the display change to Maintenance mode.
3. browse to 0163 and press ENTER - reset fuser
4. pick EXECUTE and press ENTER
5. turn the copier OFF, wait 20 seconds and power up the machine.
If C 6000 goes away it was a false error if NO ...try again and if the C6000 persist means the thermal fuse it is blown so you have to replace the fuse = call for service.
Sep 25, 2008 | Kyocera FS-1118MFP Laser Printer
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera TASKalfa 180 Copier Logo
110 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
