Question about Indesit WA 125 Front Load Washer
Cant get pump out of the machine - Indesit WA 125 Front Load Washer
  • 3 Answers
Go to appliancerepair.com
Posted on Apr 12, 2014
Big green clean machine cant get water to come out cant hear pump can you help
OPEN THE PUMP LITTLE TRAP AND EVECUATE THE FILER OF THE PUMP SOME THING IS BLOKING THE PUMP
Oct 26, 2014 | Washing Machines
Hi, I haven't used my machine for 3 years. I bought it brand new and for some odd reason its not working now. The steamer works fine, however espresso does not come out after I insert pod and switch on...
EXPLANATION: It is normal at that type of machines when they stay long unused you may have trouble with pump. The pump has 2 non return valves, very small and very sensitive ones. If they don't work properly the piston of pump cant pump watter for brewing coffee. SOLUTION: 1 - You should replace the pump, it will provide pressure and you will be able to get coffee from coffee brewing outlet 2 - (in case you cant get new pump fast enough) You open the pump carefully, the non return valves are in outlet part of pump. Before opening you can try blowing with compressed air = 4 bar (5-10 seconds) many times that helps to get in order the valves without opening pump.
Feb 03, 2011 | Alessi "Coban" Espresso Machine
Comes up on readout the pump blocked cant find type siemens washing machine(S 16-74)
This video will show you how to check the pump and we have other videos on how to change the washing machine pump if it needs replacing
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Siemens Washing Machines
HI our 10 year old front loading machine has stopped through a cycle and we cant get it spinning or pumping and cant open door to get out washing. Any advice? Thankyou Keith kamca@tpg.com.au
Welcome to FixYa.
There is typically a drain filter in the pump as well as a door lock release on Asko built machines, but I'd need a model number to be specific to your machine.
This is the typical procedure for machines of the past 10yrs. or so...
Hopefully this will help. if yours is different I'll have to wait for your reply with a model number before we can proceed.
Regards,
Macmarkus :)
Jan 09, 2011 | Asko Washing Machines
Cant remove the pump to change a belt
I ended up breaking the pump. I found that there is no real trick, it just gets stuck on sometimes. I worked on removing it very carefully for a couple hours but in the end the plastic cracked and needed replaced. The pump cost me $48 to replace and then the rest was easy
May 19, 2009 | Amana Washing Machines
Hi im having a real problem with my washer, at first it would not drain, now it wont complete a cycle and i cant get the door to open help gem
Machine can t go on if water is not pumped out And as long as there is water innside you cant open the door(Built in safety)Check that pump is clean and runs.Regards jan.
Feb 01, 2009 | Washing Machines
I have a washing machine that was made in mexico, the problem is the pump that send the water out is not working and I cant get a replacement, can I get a unverisal pump to match the one thats there ?
thats not possible to get a universal pump.
but you can ckeck out repair clinic webside for this pump.they will provide you the pump just enter the proper model number of your machine.you will see the pump with proper rate.u can also order the pump online.they will provide you.
Nov 18, 2008 | Washing Machines
INDESIT Washing Machine
Probably the pump or hose is blocked, remove the cover along the front bottom, of the machine, remove the filter and clean out, ensure the pump impeller is clear of debris and rotates freely.
refit the filter and try again.
Apr 18, 2008 | Washing Machines
Indesit WA 125 Front Load Washer Logo
21 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
