My godrej washing machine GDF 1201 NT does not function
Blue bottom does not rotate
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: bosch wwf1201 won't drain.
Probably a blocked filter that needs cleaning.
You should find this located at the bottom front right of washer behind drop down flap/cover.
Unscrew anti-clockwise to remove and clean.
Posted on Mar 31, 2010
  • 1548 Answers
SOURCE: Bosch washing machine WFT 8010
Some dryers have a "fluff" or "no heat" setting that spins the dryer with the heaters turned off. Check to make sure your cat didn't step on this button : ).
The most common failure modes include the main temperature regulating thermostat, overheat thermostat or thermal fuse, and heater elements. If you have a blown thermal fuse, check to make sure you don't have a lint buildup in the vent ductwork, especially right at the blower outlet. I've also seen problems with broken heater wiring and burned-out contacts in the heater control selector switch. The bottom line is that if gets to this point, you'll need to find the wiring diagram hidden inside the control panel, get an ohmmeter or continuity tester and start tracing the heater wiring.
Posted on Nov 18, 2010
caroldon
  • 17129 Answers
SOURCE: Washing machine will not drain
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Sep 27, 2012
When stachi do, not move clothes.
Godrej front load washing machine model no GWI5511 RES. Error e 5
Apr 20, 2017 | Washing Machines
WHICH IS COLDER 1 OR 7
gvfdhdfgdf
gdfg
dfg
df
gdf
gd
gdf
gdf
gdf
gdf
g
fdgd
fg
fgfg
fgdf
gfd
gdf
gd
gdf
gdf
gd
fgdf
gd
fg
fdg
dfgdf
gfd
gf
g
dfg
fgfdgfgf
fg
g
g
df
gd
f
fg
f
g
i think you should google it
Jul 09, 2014 | Hamilton Beach 1.7 Cu.ft. White...
Godrej eon washing machine e2 problem.
eco wash fault this can be down to hard water areas, the switch for the water intake is stuck can be opening but not all the way so it shuts it back off and you get this code.
May 09, 2014 | Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
Bosch wwf1201 won't drain.
Mar 30, 2010 | Bosch Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
