Question about Whirlpool Washing Machines
Message F02 on AWOE 7248 washing machine - Whirlpool Washing Machines
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: My Whirlpool AWOE 8748 washing
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 28, 2010
  • 89 Answers
SOURCE: Whirlpool AWOE 9559B 1200rpm 6th
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Posted on Jan 23, 2011
caroldon
  • 17130 Answers
SOURCE: whirlpool Awoe 1012 bearing
Check this link for spares and tips to replace: bearing replacement
Posted on Jul 06, 2012
Why is it displaying SUD and F02?
remove the top of the unit and inside is the trouble code paper work that will guide you to anything that is wrong.
Feb 14, 2016 | Whirlpool duet Washing Machines
Errore f02 modello awoe 8104
open the bottom tray door on front panel 3 screws on bottom front.
clean out the trap
May 10, 2014 | Whirlpool Washing Machines
Whirlpool Awoe 1012 bearing
Jul 05, 2012 | Whirlpool Washing Machines
My Whirlpool AWOE 8748 washing machine was showing error message F13. I swithced it off via the plug but the door will not open. Tried to switch it on again but no lights come on why?
Sep 04, 2010 | Whirlpool AWOE8748 Front Load Washer
I have a Premium WD602 washing machine which is stopping halfway through the rinse cycle and displaying the F02 error message. How can I fix it?
Have you cleaned the filter ? it is located at the bottom, right hand side at the front. You can't see it unless you remove the plynth. It simply unscrews so you can clean it.
Mine was also showing F02 and wouldn't complete the cycle. After cleaning the filter it was fine.
Aug 20, 2010 | Washing Machines
It is an awoe 8558. the spanner symbol is flahing
Hi, I have exactly the same problem. Did you ever get a solution to get the door open manually?
Apr 01, 2010 | Whirlpool Washing Machines
My whirlpool washer keeps sending me a message of F02? what does that mean?
the F02 message is an error message,try to check the settings on your washer or put it off and remove the plugg from the mains after some time plugg it back into the mains and put it on
Feb 27, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
F02/Sud error message fabric softner will not dispense
The pressure switch is sensing that there is still water in the unit,it sits at the top of machine under the top cover,it is round and usually red in color remove the hose/tube from it and blow through it to make sure it is clear,you can also remove the switch itself and lightly blow into it you will hear a couple of clicks put it back together and give it a shot..
Sep 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We are getting a F02 error message on ou washing macjine
Is this a Whirlpool Washer? If so, the F02 means that it is not draining properly. YOu need to check drain hose for clogs
Apr 26, 2009 | Washing Machines
Washing Machines Logo
62 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
