Question about Hozelock 2490 Auto Reel 20m Hose 12.5mm
2595 autoreel opening up case
Ratchet system not working need to open up main case. have removed all screws but not sure how to remove handle and hose feed loop without breaking them.
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Replacing the heater core i need to see where the screws are in the black box
Check this procedure for 1993 Ford Taurus 3.0L FI 6cyl REMOVAL & INSTALLATION
(see Figures 1 and 2)
Be sure to consult the laws in your area before beginning any procedure which requires servicing the air conditioning system. In some states, it is illegal to perform repairs involving refrigerant unless the work is done by a certified technician.
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
When removing the instrument panel, it may be beneficial to have a friend or assistant help you.
Without Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the instrument panel on 1986-89 vehicles as follows:
    1. Remove the four screws retaining the steering column opening cover, then remove the cover.
    2. Remove the sound insulator under the glove compartment by removing the two push nuts securing the insulator to the studs on the climate control case.
    3. Remove the steering column trim shrouds, then tag and disengage all electrical connections from the steering column switches.
    4. Remove the four screws at the steering column bracket to remove the steering column.
    5. Remove the screws retaining the lower left and radio finish panels, then remove the panels by snapping them out.
    6. Remove the cluster opening finish panel retaining screws. On Taurus remove the jam nut behind the headlight switch and the screw behind the clock or clock cover. Remove the finish panel by rocking the upper edge toward the driver.
    7. Disconnect the speedometer cable by reaching up under the instrument panel and pressing on the flat surface of the plastic connector. The panel can be removed with the cluster installed.
    8. Release the glove compartment assembly by depressing the side of the glove compartment bin and swinging the door/bin down.
    9. Using the steering column, cluster and glove compartment openings and by reaching under the instrument panel, tag and disengage all electrical connections, vacuum hoses, heater control cables and the radio antenna cable.
    10. Tag and disengage all underhood electrical connectors of the main wire loom. Disengage the rubber grommet from the dash panel and push the wire and connectors into the instrument panel area.
    11. Remove the right and left speaker opening covers by snapping them out.
    12. Remove the two lower instrument panel-to-cowl side retaining screws from the right and left side. Remove the instrument panel brace retaining screw from under the radio area. On Sable, remove the defroster grille by snapping it out.
    13. Remove the three instrument panel upper retaining screws, then remove the instrument panel.
  1. Remove the instrument panel on 1990-95 vehicles as follows:
    1. Position the front wheels in the straight-ahead position.
    2. Disconnect the positive battery cable.
    3. Remove the ignition lock cylinder and, if equipped, remove the tilt lever.
    4. Remove the steering column trim shrouds. Tag and disengage all electrical connections from the steering column switches.
    5. Remove the four bolts and opening cover, and the two bolts and reinforcement from under the steering column.
    6. Disengage the insulator retainer and remove the insulator. Remove the four nuts and reinforcement from under the steering column.
Do not rotate the steering column shaft.
    1. Remove the four nuts retaining the steering column to the instrument panel, disconnect the shift indicator cable and lower the column on the front seat. Install the lock cylinder to make sure the steering column shaft does not turn.
    2. Remove bolt at the steering column opening attaching the instrument panel to the brace. Remove instrument panel brace retaining bolt from under the radio area.
    3. Remove the sound insulator under the glove compartment by removing the two push nuts that secure the insulator to the studs on the climate control case.
    4. Disconnect the wires of the main wire loom in the engine compartment. Disengage the rubber grommet from the dash panel, then feed the wiring through the hole in the dash panel into the passenger compartment.
    5. Remove the right and left cowl side trim panels. Disconnect the wires from the instrument panel at the right and left cowl sides.
    6. Remove screw each from the left and right side retaining the instrument panel. Pull up to unsnap the right and left speaker opening covers and remove.
    7. Release the glove compartment assembly by depressing the side of the glove compartment bin and swinging the door/bin down.
    8. Using the steering column and glove compartment openings and by reaching under the instrument panel, tag and disengage all electrical connections, vacuum hoses, heater control cables, speedometer cable and radio antenna cable.
    9. Close the glove compartment door, support the panel and remove the three screws attaching the top of the instrument panel to the cowl top and disconnect any remaining wires. Remove the panel from the vehicle.
  1. Drain the coolant from the radiator.
  2. Disconnect and plug the heater hoses at the heater core. Plug the heater core tubes.
  3. Disconnect the vacuum supply hose from the inline vacuum check valve in the engine compartment. Remove the screw holding the instrument panel shake brace to the heater case and remove the shake brace.
  4. Remove the floor register and rear floor ducts from the bottom of the heater case. Remove the three nuts attaching the heater case to the dash panel in the engine compartment.
  5. Remove the two screws attaching the brackets to the cowl top panel. Pull the heater case assembly away from the dash panel and remove from the vehicle.
  6. Remove the vacuum source line from the heater core tube seal and remove the seal from the heater core tubes.
  7. Remove the four heater core access cover attaching screws and remove the access cover from the heater case. Lift the heater core and seals from the heater case.
To install:
  1. Transfer the three foam core seals to the new heater core. Install the heater core and seals into the heater case.
  2. Position the heater case access cover on the case, then install the four retaining screws.
  3. Install the seal on the heater core tubes, then install the vacuum source line through the seal.
  4. Position the heater case assembly to the dash panel and cowl top panel at the air inlet opening. Install the two screws to attach the support brackets to the cowl top panel.
  5. Install the three nuts in the engine compartment to attach the heater case to the dash panel. Install the floor register and rear floor ducts on the bottom of the heater case.
  6. Install the instrument panel shake brace and screw to the heater case.
  7. Install the instrument panel by reversing the removal procedure.
  8. Connect the heater hoses to the heater core. Connect the black vacuum supply hose to the vacuum check valve in the engine compartment.
  9. Fill the radiator and bleed the cooling system.
  10. Connect the negative battery cable and check the system for proper operation.
continue...
Feb 08, 2011 | 1993 Ford Taurus
1990 taurus steps to replacing heater core
Heater Core REMOVAL & INSTALLATION NOTE: Be sure to consult the laws in your area before beginning any procedure which requires servicing the air conditioning system. In some states, it is illegal to perform repairs involving refrigerant unless the work is done by a certified technician. CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. NOTE: When removing the instrument panel, it may be beneficial to have a friend or assistant help you. Without Air Conditioning
  3. Remove the instrument panel on 1990-95 vehicles as follows:
    6. Disengage the insulator retainer and remove the insulator. Remove the four nuts and reinforcement from under the steering column. NOTE: Do not rotate the steering column shaft.
    7. Remove the four nuts retaining the steering column to the instrument panel, disconnect the shift indicator cable and lower the column on the front seat. Install the lock cylinder to make sure the steering column shaft does not turn.
    8. Remove bolt at the steering column opening attaching the instrument panel to the brace. Remove instrument panel brace retaining bolt from under the radio area.
    9. Remove the sound insulator under the glove compartment by removing the two push nuts that secure the insulator to the studs on the climate control case.
    10. Disconnect the wires of the main wire loom in the engine compartment. Disengage the rubber grommet from the dash panel, then feed the wiring through the hole in the dash panel into the passenger compartment.
    11. Remove the right and left cowl side trim panels. Disconnect the wires from the instrument panel at the right and left cowl sides.
    12. Remove screw each from the left and right side retaining the instrument panel. Pull up to unsnap the right and left speaker opening covers and remove.
    13. Release the glove compartment assembly by depressing the side of the glove compartment bin and swinging the door/bin down.
    14. Using the steering column and glove compartment openings and by reaching under the instrument panel, tag and disengage all electrical connections, vacuum hoses, heater control cables, speedometer cable and radio antenna cable.
    15. Close the glove compartment door, support the panel and remove the three screws attaching the top of the instrument panel to the cowl top and disconnect any remaining wires. Remove the panel from the vehicle.
  4. Drain the coolant from the radiator.
  5. Disconnect and plug the heater hoses at the heater core. Plug the heater core tubes.
  6. Disconnect the vacuum supply hose from the inline vacuum check valve in the engine compartment. Remove the screw holding the instrument panel shake brace to the heater case and remove the shake brace.
  7. Remove the floor register and rear floor ducts from the bottom of the heater case. Remove the three nuts attaching the heater case to the dash panel in the engine compartment.
  8. Remove the two screws attaching the brackets to the cowl top panel. Pull the heater case assembly away from the dash panel and remove from the vehicle.
  9. Remove the vacuum source line from the heater core tube seal and remove the seal from the heater core tubes.
  10. Remove the four heater core access cover attaching screws and remove the access cover from the heater case. Lift the heater core and seals from the heater case. To install:
  11. Transfer the three foam core seals to the new heater core. Install the heater core and seals into the heater case.
  12. Position the heater case access cover on the case, then install the four retaining screws.
  13. Install the seal on the heater core tubes, then install the vacuum source line through the seal.
  14. Position the heater case assembly to the dash panel and cowl top panel at the air inlet opening. Install the two screws to attach the support brackets to the cowl top panel.
  15. Install the three nuts in the engine compartment to attach the heater case to the dash panel. Install the floor register and rear floor ducts on the bottom of the heater case.
  16. Install the instrument panel shake brace and screw to the heater case.
  17. Install the instrument panel by reversing the removal procedure.
  18. Connect the heater hoses to the heater core. Connect the black vacuum supply hose to the vacuum check valve in the engine compartment.
  19. Fill the radiator and bleed the cooling system.
  20. Connect the negative battery cable and check the system for proper operation. Fig. 1: Location of the vacuum source line 86876016.gif
    Fig. 2: Heater core cover location 86876017.gif
Jan 30, 2011 | 1990 Ford Taurus
How do i fix the heater core on my ford taurus 1995
Remove heater/evaporator case. Remove vacuum source line from heater core tube seal. Remove seal from heater core tubes.
Remove heater core access cover screws. Remove access cover and seal from heater/evaporator case. Lift heater core and case seals out of heater/evaporator case.
Installation
If installing new heater core, transfer case seals to new core. Install heater core and seals into heater/evaporator case. Install heater core access cover on case. Install seal on heater core tubes. To complete installation, reverse removal procedure. Evacuate and charge A/C system. Refill cooling system.
HEATER/EVAPORATOR CASE
Removal
  • Disconnect negative battery cable. Drain coolant from radiator. Gently pull instrument panel away from right side of dash panel.
  • Discharge A/C system using approved refrigerant recovery/recycling equipment. Disconnect heater hoses from heater core. Plug heater core tubes or drain coolant by blowing coolant from heater core using low pressure compressed air. Disconnect vacuum supply hose from inside engine compartment.
  • Disconnect A/C lines from evaporator core. Plug A/C lines and evaporator core tubes. Remove instrument panel assembly brace to evaporator case bracket screw. Remove assembly brace.
  • Remove floor register and rear floor duct from bottom of heater/evaporator case. Remove nuts securing heater/evaporator case to firewall. Remove 2 screws securing support brackets to cowl top panel. Carefully pull heater/evaporator case away from firewall. Remove heater/evaporator case.
  • To install, reverse removal procedure. Evacuate and charge A/C system. Refill cooling system.
INSTRUMENT PANEL
Removal & Installation
  • Position front wheels in straight-ahead position. Disable air bag system. See AIR BAG RESTRAINT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT section. Disconnect negative battery cable. Remove steering column trim shrouds.
  • Disconnect all electrical connections from steering column switches. Remove cover from under steering column. Remove 4 bolts and reinforcement from under steering column. Disconnect parking brake release control motor from parking brake and ignition switch connector.
  • Disengage insulator retainer. Remove insulator. Remove 4 nuts and reinforcement below steering column. Remove 4 nuts securing steering column to instrument panel and lower column to front seat. Disconnect PRNDL cable (A/T models).
  • Ensure ignition switch is locked to prevent steering column from turning. Remove 4 instrument cluster retaining screws. Disconnect speed control cable and vehicle speed sensor (if equipped). Disconnect electrical connectors and remove instrument cluster. At steering column opening, remove one bolt securing instrument panel to brace. Remove one instrument panel brace bolt (below radio area).
  • Remove sound insulator under glove box by removing 2 push nuts securing insulator to studs on climate control case. Remove glove box door and compartment. Remove air cleaner housing, battery and battery tray. Disconnect wires of main wire loom in engine compartment. Disengage rubber grommet from firewall. Feed wiring into passenger compartment through hole in firewall.
  • Remove right and left kick panels. Disconnect wires from instrument panel at right and left kick panel sides. Remove screws on left and right sides of instrument panel.
  • Pull up to unsnap right and left speaker opening covers. Remove speaker covers. Working through steering column and glove box openings, reach under instrument panel and disconnect electrical connectors, vacuum hoses, A/C-heater control panel cables, and radio antenna cable.
  • Support instrument panel. Remove 3 screws attaching top of instrument panel to cowl top. Disconnect remaining wires. Remove instrument panel. To install instrument panel, reverse removal procedure.
Hope this helps...
Jan 17, 2011 | 1995 Ford Taurus
Removing heater core
This is for a 2.3L
Hope this helps, it it does please leave feedback Thank You and Good Luck
REMOVAL
  1. Disconnect battery ground cable.
  2. Drain cooling system.
  3. Raise and support vehicle.
  4. Disconnect heater hoses from heater core assembly.
  5. Remove drain tube.
  6. Lower vehicle.
  7. If equipped, remove console as follows:
    1. Apply parking brake and block drive wheels.
    2. Position transaxle shift lever in Neutral.
    3. On models with automatic transaxle, remove clip retaining shift lever handle to lever, then remove shift lever handle.
    4. On models with manual transaxle, turn shift lever handle counterclockwise to remove from lever.
    5. On all models, carefully pry upward on outer edges of console trim plate.
    6. Disconnect electrical connectors and ashtray lamp from console trim plate, then remove trim plate from console.
    7. Remove console to mounting bracket attaching screws, then remove console.
  1. Right and left sound insulators.
  2. Steering column opening filler.
Floor Air Duct Outlet 58917672
  1. Floor air outlet duct.
  2. Heater core cover.
  3. Heater core mounting clamps and remove heater core.
INSTALLATION
  1. Heater core and heater core mounting clamps.
  3. Floor air outlet duct.
  4. Right and left sound insulators.
  5. Console.
  6. Steering column opening filler.
  7. Raise vehicle.
  8. Heater hoses to heater core.
  9. Drain tube to heater case.
  10. Lower vehicle.
  11. Negative battery cable.
  12. Fill cooling system and check for leaks.
Jan 01, 2011 | 1994 Pontiac Grand Am
Where is the heater core located
Dec 19, 2010 | 1987 Ford Taurus
How to dismantle vacuum hose at the handle with the power switch on epic 6500
Good that you didn't just pry things open. If you look closely you will see several tiny plastic caps under which will be hidden screws. Remove the screws and gently separate the "handle cover" from the main handle, then slide the handle off the hose. Clean the internal handle contacts and the rings on the hose. Reassemble by installing handle onto hose fully to align contacts, then installing wiring cover portion onto the hand grip.
Any evidence of black pitting on the rings needs to be polished with fine sandpaper and the finger contacts adjusted for tension to eliminated further shorting. After cleaning, you can apply a very thin film of petroleum jelly to the contact rings for smoother rotation.
Dec 11, 2009 | Electrolux Epic 6500 Vacuum
I cant open the glass on my back hatch any suggestions?
The glass hatch release handles fail all the time on these models (which is why the system was eliminated in 2009 models).
The glass hatch handle is $32 list from the dealer.
Removal and replacement requires a philips screwdriver and a 10mm socket and ratchet with extension.
Open the glass hatch by manually activating it through the access hole on the inside of the tailgate (small square panel covering it)
Remove the two philips screws and the one pop fastener holding the plastic trim on the back of the glass hatch handle area.
Remove the two 10mm nuts holding the handle on, unplug the wire and remove, noting the routing of the wiring on removal.
Reassemble in opposite order, being sure to route the wiring correctly.
Oct 29, 2009 | 2004 Mitsubishi Endeavor
Button worn and stuck
There are a series of molded plastic "hooks" on the top & bottom case running along the handle seam. Once you get the 6 bottom screws out, carefully (!) work a large flat-blade screwdriver between the case halves as it opens, working toward the handle. With careful application of pressure, the handle seam will pop apart. These hooks were only in the very first from production Carousel 4xxx & 5xxx and the Ektagraphic III series. Now you know why they were removed - - it's a pain to get the projector open !!!
Dec 09, 2008 | Kodak Carousel 4600 Slide Projector
Hozelock 2490 Auto Reel 20m Hose 12.5mm Logo
69 people viewed this question
Top Hozelock Garden Experts
richie46
Bill Boyd
Vernon Taylor
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
