Watch bbc iplayer
I have an LG 3D HD Smart TV & have accessed iPlayer (both TV & radio) on it without problems,until 1 month ago when I could not access iplayer radio through my TV. The opening page, listing programmes, comes on I then click the programme I want to hear only to get a pop-up saying 'Network error - try again' which I do with the same result. I have contacted LG (& reset to factory settings) & the BBC, but no one has suggested a solution. Can anyone help please?
4 Suggested Answers
  • 1570 Answers
SOURCE: Love expat shield. BBC iplayer
Hi there !
You need to upgrade the flash player you are using because the website does not recognized it anymore or it needs higher version of flash player installed in your computer. I have same problem this before and it works.
I am sure it will solve your problem.
Posted on Feb 05, 2011
SOURCE: I cant't get bbc iplayer
I am having the same problem,same error message. I only get the message when trying to view live TV using the iPlayer. The BBC News channel plays live OK through the BBC News website. Live sport broadcasts play OK though the BBC Sport website. I uninstalled Flash Player and then reinstalled. It made no difference. Please help.
Posted on Sep 12, 2011
bronk50
  • 27725 Answers
SOURCE: missing hss.dll driver file
You could run the chkdsk utility. Cick start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility Cick start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors then select check now start should schedule this task when restart it will only schedule on restart if its the Primary hard drive with an operating system on it do not do anything while the chkdsk utility is in progress any input may damage your operating system and your computer. Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps: Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow. Type the following command, and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Posted on Dec 13, 2012
How do i use the bbc i player app installed on the tv
There are several different versions of BBC iPlayer which manufacturers use in their devices. Between these versions, due to technical limitations, there can be some variations in features (subtitles, HD etc.). Each device will need to be connected to the internet to use BBC iPlayer.
Without knowing the make and model this is the info available.
Dec 23, 2016 | Televison & Video
Why does my tv led40 keep freezing when I try to watch iplayer
I no idea how I got this question I have not got a HD TV let alone smart. Is the format compatible on them both ?.I can not help apart from that sorry .??
Feb 20, 2015 | Samsung UE40F6400 - 40"" LED-backlit LCD...
Bbc iplayer homepage
try turn off your iplayer and afte 30 sec turn on iplayer
Jun 13, 2014 | Computers & Internet
Bbc iplayer
U must set up iplayer output to 1080p it is full hd or better if You have ultra hd reciver and tv
Jun 09, 2014 | Computers & Internet
No sound on iplayer on tvonics z500hd
Workaround procedure to get this to work 1. Go to BBC1. 2. Go to the Guide and select channel 200 - BBC Red Button. Press OK. 3. Exit the Guide and wait. You should see a notice about the BBC Red Button Service. Wait a few seconds. 4. Press the RED button - the display switches to BBC1 and shows the standard (Text) Red Button Index. 5. Press the BLUE button to close the Index. The display shows the BBC1 video and sound. 6. Press the RED button to get into the Red Button Menu. 7. Wait a few seconds and then select the BBC iPlayer. I gained access to the iPlayer once this way yesterday and twice so far today but when I went straight to the iPlayer from BBC1 I lost the sound. I've just shutdown and then re-started the HD500 and successfully accessed the iPlayer using the above method. Note, that if it doesn't work then just switch your box into standby, wait 15 minutes or until the Hard Disk stops and then you can switch it on again. No mains power-off or reset is required.
Mar 29, 2013 | TVonics Televison & Video
BBC Iplayer App keeps hanging
It is probably a signal issue. Check by resetting your router.
Nov 24, 2017 | Samsung Computers & Internet
Using Ex Pat Shield, BBC progs no longer start and a notice, 'Task failed at step 0: config was empty.' (Or 'Task queue failed ditto' Everything worked fine just days ago.
I have exactly the same problem, same error message. I first noticed the problem yesterday (September 11). Error message appears when trying to watch live TV through iPlayer. BBC News Channel works OK from BBC News website. Live sports broadcasts work OK through BBC Sport website. I uninstalled and reinstalled Flash Player but it made no difference.
Sep 12, 2011 | AnchorFree Expat Shield
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
