Question about Teac Televison & Video
Makes noise makes loud sound when loading up and playing disc
  • 1003 Answers
SOURCE: Samsung DVD/VCR combo (DVD v4600) makes loud sound when playing dvds
probably cheaper to replace than repair sounds like theDVD drive has worn parts or is about to go out.
Posted on Jan 15, 2008
SOURCE: Loud clunking when loading & playing....
Same problem. Took mine apart, and it appears that shaft of the motor that spins the CD/DVD has gotten wobbly - probably due to a worn bearing. This would explain
Not worth fixing - even if you could find a replacement motor. DVD players are so cheap and feature-rich now, that it would not be worth the time and money to replace just the motor.
I would not continue to use the player in this condition. I noticed some white dust around the rim of the tray when it is open - that tells me that the DVD is scraping on the tray. There is a serious risk of damaging your media. And considering that you can get a brand-new DVD player for the price of 2-3 DVDs...
Posted on Jul 03, 2008
  • 289 Answers
SOURCE: loud mechanical noises from my dvd player during loading,advcing,
hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
Posted on Feb 07, 2009
eagle338
  • 4889 Answers
SOURCE: dvd makes strong playing sound. normal?
From the info you have given, your player is probably running a few degrees hotter than usual. This causes the fan to spin at a faster than usual speed causing that noise. It can happen if you keep your player in an enclosed space blocking the heat vents from dispersing the heat. Make sure that you place it in a location where it can disperse heat more easily. This will hopefully resolve the issue.
Posted on Apr 22, 2009
sonicboomele
  • 1557 Answers
SOURCE: BD30 makes a grinding sound when loading discs,
in most cases its a bad disc but if all disc are doing it then your glide tray needs to be re alined
Posted on Jul 04, 2010
GE front load is making loud banging noise during spin, any ideas how to fix?
Sounds like what happens in a top load when the load is "out of balance". I suppose it's less likely to occur with front load. Test with a "light" load. Is the washing action a reversing action? If so there may be a transmission problem.
Apr 11, 2015 | GE Washing Machines
The player makes a terrible noise when trying to play the disc. The disc wont load
I will strong recommend you to go to the repair shop TV for fix.
the reason is there many servomechanism inside that need LUBE , or replace gear broken or worn, or belt worn.and shaft needed lube and adjust it.
However see the flowchart.God bless you
7_21_2012_1_55_31_pm.gif7_21_2012_1_55_50_pm.jpg7_21_2012_1_56_03_pm.jpg7_21_2012_1_56_41_pm.jpg
Jul 20, 2012 | Televison & Video
Xbox makes noise playing discs
I know what you mean , some drives are LOUD .Try wraping it
with towels ,just kiding . I have recived alot of request to quite
these drives down , I am working on a sound insulator
that will wrap around the cd rom to knock 10-20db off
but i have to watch out for heat build up. Ill keep you posted.
Bobby.
I presume the unit works fine it's just loud, right?
Rob
Sep 16, 2009 | Microsoft Xbox 360 Console
Loud buzzing noise
Mine is loud also when playing games. When playing DVD's it is not. I think it is a factory defect on some of the systems. I would not attempt to pull apart the DVD drive and try and fix it. It is working and on an XBOX 360 you should feel lucky that it is.
Aug 18, 2009 | Microsoft Xbox 360 Console
Loud mechanical noises from my dvd player during loading,advcing,
any noises.
check it out.
thank u..
Feb 07, 2009 | Philips DVP5140 DVD Player
Mar 30, 2008 | Toshiba SD-2800 DVD Player
Loud noises
Depending on the age of the system, replace or ignore.
Its your DVD drive, unfortunatly most drives are noisy -FACT- so sometimes you have to just live with it- check the back ,if manfactured in 2005 ( a lot of bad drives from this year) might be worth ringing microsoft to see if an exchange is possible.-
But if its not showing any loss of play/loading or scratching the discs - or showing error- please place disc in a xbox 360 console...You may just have to put up with it.
Jan 24, 2008 | Microsoft Xbox 360 Console
Jan 13, 2008 | Samsung DVD-V4600 DVD Player/VCR
Wii
some loose connection inside or change your sound settings
Oct 21, 2007 | Nintendo Wii Console
Televison & Video Logo
Top Teac Televison & Video Experts
bengsoon Neo
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
