Question about DeLonghi Coffee Makers & Espresso Machines
Coffee machine not switching off - DeLonghi Coffee Makers & Espresso Machines
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
Faulty power switch
Posted on Jun 21, 2014
Where can you buy parts
The on/off switch is not available to retail end users from Mr. Coffee. I checked ereplacementparts.com (which has a good supply of parts for almost anything), and they recommend contacting an authorized Mr. Coffee repair place. (http://www.ereplacementparts.com/coffee-ecm20-espresso-cappuccino-parts-c-116130_116133_116388.html) So if you wanted to do it yourself, you'd have to find an aftermarket switch to use, rather than the OEM.
Sep 16, 2014 | Mr. Coffee ECM20 Espresso Machine
Gaggia syncrony compact will not switch on
I have had this problem. The main switch on the machine burned over and I had to take it to a maintenance to put a new on. I do not know if there is a fuse on the machine. It was not in my case anyway.
May 28, 2014 | Gaggia Syncrony Compact Coffee...
Lite is on will not brew there is water and coffee and it doesnt brew
You can try this.
1. Plug the coffee maker into the wall power outlet. Turn the switch on. The light will glow. Then press the on/off switch TWICE. The coffee maker will start.
2. If the machine doesn
Aug 02, 2011 | DeLonghi DCM485 Coffee Maker
I have had the machine for two years and it just died. None of the dials or toggle switches work, the digital clock display is dead, the coffee maker will not receive power. I have tried different...
The thermal fuse is probably open, it is usually welded to the heating element and tied into the on/off switch, and usually involves the replacement of the bottom section. The thermal fuse prevents the coffee machine from over heating.
May 04, 2011 | Cuisinart DCC-1200 Coffee Maker
The machine does not stop grinding - until all the beans are up & everything clogs up inside
Hi
The problem with a constant grinding and overflow of coffee is a micro switch in the doser box needs to be replaced. If you get the top off there is a solenoid in the center of the machine on top that has to be removed. There is a micro switch below and to the right that is bad or dirty and needs to be replaced. This micro switch turns off the grinder when the coffee pushes a arm against the micro switch. If the micro switch doesn't shut off the grinder the coffee overflows the box and falls into the brew unit. This is a very special micro switch that is only a 6 gram switch not like the others that look like it and are a 32 gram switch.
Feb 06, 2011 | Solis Master 5000 Espresso Machine
When I turn on the machine it says warming up and rinsing but it doesn't rinse and I can't get it to make a coffee it won't go past rinsing
Probably overheat protector thermal switches on the water boiler is tripped. Need to open the machine and reset those switches by pushing in the pins on the switches.
OR the element on the boiler is blown.
May 25, 2010 | Saeco Royal Digital Plus Coffee...
Nespresso Krups essenza manual XN2001- Switch broken
The machine is not switching on-I am in India-Tamilnadu-can i get it serviced any where here?
Jul 29, 2009 | Nespresso Essenza C100 Espresso...
Dualit 889 espresso coffee maker problem
To pull a shot
1) Turn machine on (innermost right switch)
2) Red light goes on (power on)
3) Yellow light goes on (thermablock heater)
4) Wait for yellow light to go off
5) Detach handle (pull to left)
6) Clean handle, remove crema sieve, clean with soap & water
7) Put crema sieve in handle (you should have a choice of two)
8) Put espresso ground coffee in with brown handle
9) Tamp coffee down FIRMLY with handle
10) Place handle back into machine (push to right)
11) Ensure flip switch on leftmost side is at top position
12) Flip down rightmost switch to infuse coffee into handle
13) Wait 18 - 24 seconds
14) Flip up rightmost switch to turn off infusion
15) Put milk into container (about 200ml in a 600ml container)
16) Flip down rightmost switch to bottom position = steam
17) Keeping tip about 5mm from top of milk, foam to ~400ml
18) Place sugar in coffee, if desired
19) Pour milk in coffee
LATTE
YUM
May 06, 2008 | Dualit Espresso 889 Espresso & Coffee...
Coffee Makers & Espresso Machines Logo
24 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
