I was watching my kp61v80 and the screen went black-can you give me the trouble codes for the flashing standby light
  • 8,617 Answers
Diagnosis item
TIMER/STANDBY
Indicater
Number of blinks
Supposed malfunction Condition
Self-diagnosis
screen display,
Diagnosis item: Results
•Power not ON 0
[Standby Power Supply System]
F601 open.
R607 open.
Q601 short circuit
[Main Power Supply System]
IC601 and R612 are broken.
VDR601 short-circuit
Cannot turn on the power.
LED doesn't blink.
+B OCP detection 2times Short circuit of power supply system in each circuit.
Goes to the standby mode
Short circuit of +B line
2 : +B OCP 000
+B OVP detection 3 times
T603 pin 78 open.
R672 open.
Malfunction of power supply circuit
3 : +B OVP 000
Vertical deflection stop 4 times
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Raster goes to one line horizontally, Aand then video
signal is muted.
4 : V Stop 000
Video out abnormality detection 5 times
Video out, Q705, 732, 761 and others in C board
circuit.
Q218, 219, 220 (A board)
TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
5 : AKB 000
Horizontal deflection stop 6 times
C515, 516 open.
IC206(YC Jungle) is broken.
Raster doesn't appear. 6 : H Stop 000
Audio abnormality detection 8 times
IC406(Audio amp.) is broken.
PS401, 402 open.
The sound is not out.
8 : Audio 000
Posted on Jun 18, 2009
LED tv screen went black. How do I fix it?
Look at the website shopjimmy.com. They have trouble shooting videos to determine if it's power supply, led driver, led strip, or t con board.
Dec 06, 2015 | Panasonic Televison & Video
Standby/timer flashes and screen goes black
How many times do this standby light flashes at one time switch ON? Count it. These flashes are fault indications. From the number of flashes, you can get an idea about which section circuit inside it is faulty. After confirming it, If you wish to get more details of these blinking codes, check this link.
Mar 02, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
Oct 17, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Watching tv/w a dvd/vhs player(a seperate machine)the power goes out on the screen.went out with a white flash like usually when i turn it off.now on the bottom where the control buttons are,a red light...
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Mar 04, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony KP-46WT510 Picture went out (completely
Your Sony TV needs Screen (G2) volts adjustment and I'm not sure that you can do that or not by yourself.
If you are confident and know electronic stuff repair, then let me know to guide you OR call local TV tech to perform adjustment.
Thanks.
Oct 30, 2009 | Televison & Video
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Philips 42PF9630A 42 in
Wow that is a lot of money in any currency. Coming from England its not uncommon to be paying £200+ to repair a tv like yours. If you could give a little more information then maybe I could narrow it down for you. You say its gone black but does your standby light still come on? If you try to turn it on with the remote control does the stanby light flash quickly then re-appear? Or does it come out of standby and have a black screen? Can youm get sound through a dvd player but no picture? If you can answer these questions who knows maybe he will do it cheaper if you supply the part yourself!!! Dont think he will but worth a try :-) please post again.
Aug 25, 2008 | Philips 42PF9630A 42 in. Plasma Television
Standby Lamp
Count the flashes of the standby light and the gap between them as this will give you the exact error code for the fault. Then check handbook or sony forums for the solutions. Like I have said in other posts sony and 3rd party dont really go together but it does not mean that because I have had those experiences it applies to all products and components. Hope this helps.
Aug 18, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Jun 17, 2007 | Bush 5693D 24" TV
Televison & Video Logo
269 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
