Question about Sony Mavica MVC-CD400 Digital Camera
Flash does not work...
I took some pictures on the beach and noticed that they where blury, like with fog. It was a very bright day, so I decided to change some of the settings of the camara (Mavica CD400). After that, I have not been able to use the automatic flash anymore. I mean, during the night or when it is very dark the automatic flash does not come out. I know I screwed up the settings, but I love this camera so much I am afraid I damaged it... I read the instructions manual looking for a solution, but I have not been able to set it back to the way it was. How do you think I can fix this problem.
  • Potranca Jan 11, 2008
    null
  • talaat saleh Nov 25, 2008
    (Mavica CD400zoom not working
    President:
  • 4,402 Answers
Use the tumb wheel till the lighting sign on the lcd comes up
Posted on Jan 08, 2008
  • Cary Farah
    Cary Farah Jan 11, 2008
    on top set the mode dial to the camera picture
    with the thumb dial use the up "^"
    press it till the flash symbol comes up
Display screen does not show picture
Could be your camera is still working, but some settings are messed up?
You could have turned off the display. In the menu with IMAGE DISP. Is used to save battery power.
Then try making pictures in the mode automatic. Because if you switched to scene like bright sunlight or snow your pictures can be very dark.
Jan 16, 2014 | FUJIFILM Cameras
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
My camera is set on autoflash but it flashes even in the bright day- light resulting in over expose, what could be wrong? It takes good pictures at night.
Yes I believe I fixed my problem. I shined a bright flash light at
the light sensing photocell and took pictures with it (no flash).
Then I darkened it, took pictures (it flashed). I did this back and
fourth and it seemed to work although I have not tried it in the
field yet. Thanks for your offer of help and I do think your
rates are reasonable.
Anthony 12-6-09
Dec 06, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Blury view finder
On the left of your viewfinder you will find a small knurled wheel. By turning this wheel you adjust the diopter settings of the viewfinder. You probably accidentally moved it and didn't know it.
Aug 11, 2009 | Olympus SP-550 UZ Digital Camera
Philips 50p8341a - 1) Periodic flashing, 2) Haze over picture
maybe you need open the tv the upper case and need to clean the mirror and the lens
Jan 13, 2009 | Philips 50P8341 50" Rear Projection...
Blury and flash problems
Hello Chad,
As you told the condition of the are blurry,This problem is not related to the setting or master reset.This cause is due to malfunctioning of zoom optical motor and sensor who focus the object.Therefore, the solution of it is, You have to change its optical lens assembly.
I often deal these sort of cases in routine in said Model Although it's a very fine camera but dusty and moisturized conditions cause this problem.
Thanks & don't forget to rate.
Apr 12, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Pictures are too bright
sir i think this is sutter EV slow or ur AV in lens not operating, u remove ur battery some time.and reset
Mar 04, 2008 | Nikon D40x Digital Camera
Very, very dark (almost black) lcd screen, but is functional
The LCD viewer is made up of the LCD screen, and the backlight. Your backlight is burnt out, or the circuit board isn't sending power to it. Backlights can be replaced separately.
Sep 04, 2007 | Logitech ClickSmart 420 Digital Camera
Blury pictures
change the resolution setting in setting. and also you can adjust diplay bright ness and contrast for bets view & pics .thsi will solve the problem. Thanks Sangita
Jul 08, 2007 | Samsung Digimax S500 Digital Camera
Sony Mavica MVC-CD400 Digital Camera Logo
42 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
