Question about Garmin Gpsmap 5212 Multifunction Chartplotter
Garmin 5212 error code 5
When transmitting radar i get an error code 5 and radar stops transmitting
2 Suggested Answers
issy2
  • 462 Answers
SOURCE: Garmin radar error code 8
Have u checked with the antenna terminals... i suggest u to remove antenna contacts clean them using WD-40 for best and put them back.. Hoping to hear form u ..
Thankyou
Posted on Aug 05, 2008
My garmin 5212 has nothing but lines on the right side what do i do
All you can do is send in to Garmin for repair. Call them for pricing.
Sep 19, 2017 | Garmin Computers & Internet
check the battery, some error due to battery problems, and then rest it for a while and then test.
melnavz
Aug 05, 2008 | Garmin Boating
My panasonic air conditioner model CF-E24GKR is does not appear to be working the green power light is flashing and it is blowing cold air
14.2.2 To Make a Diagnosis:
1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
When you have the error code you will be able to diagnose the fault.
Jun 06, 2017 | Panasonic Heating & Cooling
We have a garmin gps map 4012 and on radar just says radar error
This is a marine chartplotter and radar unit! I thought I didn't recognize the model :>) Check the connections are the rear, but more importantly to the connections to the radar dome.
The manual is here, but doesn't mention errors. You could of course contact Garmin direct.
http://jsca.bc.ca/wp/wp-content/uploads/2013/12/Garmin-5008.pdf
May 03, 2016 | Garmin GPS
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
2. Press the CHECK button on the remote controller
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
Radar 1731 shuts down when tx is hit
There are a couple of things that could cause the radar to power off when going into the transmit mode.
The first thing to eliminate is input power. When in the standby mode the radar draws less current than in the tx mode so if you have low voltage for whatever reason, that could cause a shut down. Check all connections and measure the voltage to the unit while it is on.
A problem with the antenna motor or gear box could also be the problem. The antenna doesn't rotate unit the unit is switched to the tx mode. You would need to remove the dome cover (with unit off) and verify that the array will turn freely by hand. Typically, a bad motor will not cause a shut down but a physical obstruction could.
Focus on the power issue because that's the most common problem. Be aware that you need to measure the voltage as close to the radar display as possible and watch the voltage as you switch the radar from standby to transmit for a quick dip in voltage.
Jun 25, 2014 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
PC Port stops working
Class of service option disable PC. Port. Or the the hp port is not tagged/untagged to the wrong vlan.
Oct 16, 2013 | Mitel 5212 IP Phone
My ship furuno radar hasn no sweep only a center dot.all other fed in information like speed,GPS input o.k.
The symptom you describe sounds like a case of no radar targets. To further diagnose, put radar on the longest range and turn Gain to full, Sea Clutter to Minimum, Rain Clutter to Minimum, and observe the screen. The presence of "grass" or evenly distributed clutter indicates that the receiver and cabling is good and the radar may not be transmitting. No transmit is caused by a bad magnetron or a bad modulator in the antenna, or depending on model there is still an outside chance that the power supply in the display has failed.
Dec 29, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Police radars can they be picked up by garmin
no the garmin 255W is not a radar or laser detector.
Oct 25, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Gpsmap 5212 Multifunction Chartplotter Logo
79 people viewed this question
Top Garmin Boating Experts
Mohamed Ismail
Mohamed Ismail
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
