Question about Microwave Ovens
Defy Oven Slimline 600c wont heat up - Microwave Ovens
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
I have a Defy Gemini Petit Chef oven and glass hob combo. On e plate on the hob appears to heat up to maximum temp irrespective of the setting on the control. The other plates seem to be fine. Is there...
If it is a "Hot Plate" then the thermister is probably within the plate and replacement of the plate may be required.
Call a qualified appliance repair person for an estimate of the cost to repair.
Mar 23, 2011 | Microwave Ovens
Wont heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jkfk
Nov 06, 2009 | GE Profile Spacemaker JVM1871 Microwave...
Panasonic Slimline Stainless Steel Combination Microwave
First of all, is the hole a factory one that you never noticed before? If so, leave it alone. I know that microwaves generate a lot interior heat and it needs to escape someway. Secondly, if it is not a factory made vent hole and you can't be sure if it caused from a lot of use, and if the oven still works fine, I would not worry about it if it were me.
Mar 10, 2009 | GE JVM1630 Microwave Oven
3 microwave ovens in 18 months - all won't heat up - what is causing the recurring problem?
Carla, Sorry to read of your troubles. Your unit that is only 2monts old should be under warranty, or did you receive any warranty?
What you describe as " the noise one gets when metal is put in by mistake". The noise is Arcing of Microwave Energy. Do not operate a Microwave Oven DRY (without something inside that will absorb the Microwave Energy. A Dry-Run Microwave Oven will feed-back upon itself and do damage.
If your unit is matched to the electric needs, both voltage and cycles, then I would not get another one of the same Model.
Feb 02, 2008 | Microwave Ovens
Advantium -- wont cook
The solution to this problem is to replace the magnetron. I had the same symptoms, and I got a used magnetron and replaced it. It takes some advanced electrical skill, and you have to disassemble the oven all the way to the inside stainless steel. I have the same exact model, manufactured in November of 1999.
Jan 13, 2008 | GE Advantium SCA2001BSS Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
