Question about Ovens
Lif90eg oven does not heat up fan works griller works but no fan
4 Suggested Answers
SOURCE: BLANCO Stove Not heating up
Resolved, I took the fan cover off and the round elementjust fell apart, so I'll get a new element and all should be OK.
Regadrsd,
john S.
Posted on Jun 21, 2009
SOURCE: Oven-part of Franke Stove not working.
I have a Franke gas stove top and under one burner knob the spring is broken. Model #AD 72 M WQ
Posted on Apr 28, 2011
mikadot
  • 2113 Answers
SOURCE: miele 310 oven griller works but not the oven. why?
Remember that some parts of a 240 volt stove require two live wires and most of the controls or elements being only 120 volts require just one live wire. Hence the double pole 40 amp breaker must have tripped but does not appear tripped. Just turn it off and back on to reset
Posted on Nov 17, 2013
Do I need to remove oven griller when using oven
No.
The grill tray should be able to handle the heat fine.
Oct 11, 2014 | Ovens
Miele 310 oven griller works but not the oven. why?
Nov 17, 2013 | Miele Ovens
I have St. George Imperial Fan Forced Oven with Griller (Wall Oven) SGW FO need measurements and specs also model number ?? Can someone please help me have been looking on net for ages...Getting...
you should find the model number between the bottom of the griller door & the liner .. silly place really to get at... as you cannot remove the grill door as you can the oven door.
we have just rebuilt one from two we acquired ... best oven ever .... there will be a few different models as these were produced & cosmetically changed over a 20 yrs period. Ours now looks like a brand new oven as they are REAL baked enamel ... you can clean with caustic based product without any harm.
I am searching for a manual if anyone has one mine is 67/wdl.v.81.fo I presume the 81 in the number denotes 1981 manufacture.
Don't be fooled if you find the oven does not heat at some stage & everything else works ... this is usually after a cleaning & the auto on & off timer has been activated ...just a matter of setting back to manual mode.
Hope this helps although you have probably solved by now having posted in April 11.
Anyone have a manual for this model would be appreciated .
Apr 16, 2011 | Ovens
ZBF360X Electric Single Oven: fan oven working but no heat...
If the main oven fan is working but no heat it is most probably the ring element which is around the fan blade inside the oven.Check it is the element before you go and replace because there could also be an issue with the thermostat.Hope this helps.
Good Luck,
May 07, 2010 | Zanussi ZBF360X Electric Single Oven
How do I ignite the oven on a Chef Benchline 540?
The ignition for the griller on our Benchline 540 isn't working properly - it takes about 10 tries then explodes. Any ideas?
Mar 07, 2010 | Magic Chef 9122 Gas Single Oven
Jul 10, 2009 | Ovens
Regadrsd,
john S.
Jun 18, 2009 | Stoves Ovens
Cant get griller door back on
If your prob has not been solved yet, try this solution.
In your browser bar type in youube.com
Then in the sesrch box type in fitting oven door hinge
Click on appropiate video and follow instuctions.
This should help.
Plz rate my solution.
Thanks.
Dec 22, 2008 | Ovens
Instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Sep 11, 2008 | Ovens
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
18 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
