Question about Cables Unlimited 900MHz Wireless Rock Speaker System Speaker
How to hook them up by the lake
Im going to buy these and my reciever is in the house and want to hook them up down by the lake.
  • 47 Answers
By the look it is wireless. It should come with something to attach to the amp for the signal. It should work fine.
Posted on Jun 17, 2009
Evet time i hook my 1200 watt power acoustik and turn it up it cuts off
Usally When something like this occurs its because the amp cant handle the reciever. Meaning the reciever is pushing out more than what the amp can handle. As a safty feature to save you from blowing your amp or speakers the amp will shut it self down to minimum as you described. This also occurs when the amp over heats or doesnt have enough ventalation and once again as a safty feature to save your amp it shuts down. My first suggestion is to turn the "Loud ON" mode off on your reciever. As this feature can blow your speakers and can also cause this problem. Also do not use any factory settings on your reciever. It is almost always the bass in any given system that causes this so turn the bass down some on your reciever or on your amp turn it down and then adjust up and down from the reciever. Im sure you probably like the bump bump bump, I do to but your going to have to eiather buy an amp that can handle what your reciever is pushing, or turn it down a bit. You should also check the fuses for not only your amp but for the system under the hood near the battery. My own personal experience I have blown fuses when the system shuts down. Hope this helps
Oct 24, 2011 | Car Audio & Video
I have cable modem can i hook up my belkin wireless router model #f5d8236-4 v3 to it ...my son wants to play his x-box 360 while im on the computer...please help
theres a number of solutions
you son my have a wireless reciever on his xbox(this is either built in or can be purchased) this will allow him to access the router around the house wirelessly allowing you to keep your cable plugged in to your desktop
protip:,make sure that the router channel number is set to 11 or the xbox wont read the wifi signal
you can get an extra long cable to reach between the router and the xbox (standard cat6 cable) id buy that online as its cheaper than in the stores.this will plug into one of the ports at the back allowing him to play while you surf the net
Mar 07, 2011 | Belkin Computers & Internet
Will my tv in my bmw work after digital swich over
it needs a TDT reciever put in front of it to recieve the signal then run it via the euroconenctor .12v versions are available
Jan 07, 2011 | 2001 BMW 5 Series
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Im trying hook up a subwoofer to my reciever and its getting power to the amp, however the amp is not powering on.. do you have any idea?
did you hook up the power antenna or amp. turn On wire? make sure you should ha a wire that is to power an antenna and this is the wire that has 12 volts as soon you turn On your stereo and send 12 volts to your amp. but if you don't connect this wire, the amp will never turns On
Jan 04, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
I have a new house that had speakers built into the cieling. I bought an onkyo to push all eight speakers. the reciever went into protect mode. i had an old reciever and hooked four speakers to the onkyo...
you can check them with a ohm meter, hook it to the wires that you hook to the reciever and if you get a reading it is good if no reading it is bad wires
Nov 22, 2009 | KEF Audio Cresta 2 Speaker
9.9 johnson want open up
Is it a reconditioned lower unit?
What sort of oil did you put in the lower unit?
Sounds like there is some drag in the lower unit causing the engine to bog down. It will work fine on a stand in neautral however.
How does it go in reverse on the lake? Can you get full throttle?
Jul 24, 2009 | Boating
I have a Genesis G506 and am having problems setting it up properly,the remote seems to freeze up(i have to power it down then start again) I cant understand the setup procedure on setting up the center...
ya were did u buy the speakers.... im going to guess probably outside a bank or circuit city right??  ya its a scam there not worth sh!$   throw them away  how much did u pay btw
Sep 06, 2008 | Audio Players & Recorders
Tv hook up!?
First you must be on the audio outs in back of tv set. then you must go into menu, if not already and change audio to varible output, or external speakers or just what ever yours say in menu. then you must turn receiver to the right inputs to get sound. Hope this helps.
Sep 21, 2007 | Panasonic SA-HE100 Receiver
Cables Unlimited 900MHz Wireless Rock Speaker System Speaker Logo
46 people viewed this question
Top Cables Unlimited Audio Players & Recorders Experts
Sean Burke
Sean Burke
 Grubhead
Grubhead
Are you a Cables Unlimited Audio Player and Recorder Expert? Answer questions, earn points and help others
