Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
Colour is predominently orange/red through the lens but review of previous recordings show true colour on mini screen
4 Suggested Answers
Arpi
  • 326 Answers
SOURCE: multi-coloured vertical lines on LCD screen and view finder
Hello, there is a chance for the Sony recall. Please contact your nearest Authorized Sony Service. If you need more info please advice.
Posted on Mar 21, 2007
ctf1800
  • 4402 Answers
SOURCE: Sony DCR-HC42 Partial Screen Display
Sony has had some CCD problems with this and other model I think it is important to contact Sony at 1-866-703-7669
Posted on Feb 01, 2008
  • 9 Answers
SOURCE: LCD SCREEN-RED CLOUR ALONE NOT AVAILABLE
The problem is the ribbon cable connecting the circuit board to the LCD display.It is not very hard to replace but I have no idead from where to buy it.The missing red color is just the beggining,now my LCD sometimes turn to white and I can't see anything on it.
Posted on Jul 13, 2010
Lg tv problems
Check and replace the red colour output transisor at its video output section circuit. Check whether there is voltage at its collector terminal. If you wish to get more details about this fault [one color predominant screen] check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 01, 2013 | Televison & Video
Tip
SONY TRINITRON ONE COLOUR PREDOMINANT SCREEN
Sony Trinitron sets are of CRT [Caothde Ray Tube] types. The common fault seen in these type of TVs are any one colour predominant on screen wih sound OK. Either red, blue or green colour with some thin horizontal lines at about an inch apart will be seen on the entire screen. This is totally a display card problem, which can be seen pluged onto the picutre tube neck. There are three electron guns for every picture tube, which emits red, blue, and green beams, which in turn illuminates the phosphor on the screen to get that colour. If no emission from all guns, results in a blank screen, ie black screen without any disply at all. The three colour beams together produces proper coloured picture what we see on screen. These three gun's terminals are brought out by pins of the picture tube outside to which video signals are given in appropriate proportion to produce a TV picture. Normally, all these three pins are biased with a voltage of about 170 to160VDC+ve. Take one colour gun, as an example and and let me describe the problem.
Let it be a green gun. These guns are called cathodes of the picture tube. If it gets a voltage with respect to its grid, it will emit electrons according to the voltage applied to it. This is a negative process, that is, as the voltage at this pin drops, its emisson incresses and vice versa. If the emission increase, the colour with respect to that gun also will increase and gets predominant at the screen. So when we see a green predominant screen, there will be less voltage at the green cathode with resepect to the other two. If red colour is predominant, the voltage at red cathode will be less than the other two. If blue colour is predominat, the voltage at the blue cathode will be less than the other two.
We must find out the reason for this fault first. Assume that your Tv has a red predominant screen with some thin lines across it, at about one inch apart of the entire screen, it is clear that the the red cathode voltage is very lower than the other two. the main reason for this fault, normally seen in most of the Sony Trinitron, are loose soldering points either to the picture tube base socket or the resistor connected between the red drive transistor's collector point. Resoldering the most of these points on the base card by applying a little more solder will rectify this probelm. Other possibility is shorted video output transistor of that cathode. A direct short [collector to emitter] of these transistors will drop volatge to very low at that respective cathode of the picture tube, and that colour will be pridominant along with lines. Replacing the transistor will solve the problem. In some cases, the resistor connected to that transistor may have blown out. If so, it should alo be replaced. Whatever the case may be, voltage at the respective cathode that emits colour will be very low with respect to the other two. Find out the reason and rectify it. You can compare the voltages of the other two cathodes with respect to the faulty colur cathode. Cathode pins will be marked on the base card, and can be identified. It is best to pull out the base card from the picture tube neck and place it somewhere a safe place without shorting it with other parts of the TV. You can measure the voltages of these points very easly, without fearing the damge to the picture tube. After all are found Ok, replug the base card and switch on the TV. The set will be alright. In rare cases, chroma IC also can be a reason for this fault. if it is faulty, after a short period after switch on the TV, the IC will overheat and shutdown the entire system.
on Mar 21, 2011 | Televison & Video
Focus issues
My reply is bit technical. Your camera requires Flang-Back Adjustment.
Above said adjustment will set focus lenses in correct order / position to obtain crispy focus as it was before.
There are few special tools designed by Sony used in Flang-Back adjustment and only Sony Service Centers can perform such adjustments. Non-Sony repair shops do not have such things.
Just for reference, below view shows required tools for adjustments in this model.
Need further info let me know please.
Nov 27, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Sony DSR 250P DVCam
carefully open the camera cover on the right hand side when looking from the front.reach your finger to the flat cable from the lens that ends up as a connector on the main board. Press this connector firmly back into position and reaasemble camera. be carefull not to damage firewire flat cable that is attached to the rear part of this cover, therefore it is necessary to lift this cover just a few mm for your finger to get through.
Jul 19, 2008 | Canon MV30i Mini DV Digital Camcorder
Mini dv recorder
THIS IS A CCD.. CONTACT JVC FOR FREE REPAIR
Feb 23, 2008 | JVC GR-D33US Mini DV Digital Camcorder
Colours on TV Panasonic TX-32PL10 5/6 years old
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Feb 11, 2008 | Televison & Video
Problems from the lens
Defective ccd imager!! the
company will replace this
ccd imager free of charge.
Year 2002 up to 2005 released
unit has a factory defect ccd
imager. the company recalled
those units and replaced with
a stronger version of ccd
imager ( they are still doing it).
check it out.
Dec 12, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Nov 05, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sep 29, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
21 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
