Question about Denon Audio Players & Recorders
Rc 1049 Need guidance to connect or install
    Sergeant:
  • 231 Answers
If you go here you may find some manuals - http://denon-uk.custhelp.com/
RC-1049 by the way is a remote control.
Posted on Apr 12, 2014
Universal codes
1406 1258 1219 1142 1274 1061 1049 1141 1132 1157 1082 1217. These are the codes to check with LG brand. If you wish to get more, http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 18, 2013 | RCA RC-U703SP Remote Control
How to connect DAV-HDX265 to xbox 360 and TV
Your HDMI cable handles both audio and video. If you would like a "one" source output you need to have a reciever that has multiple inputs with one output. You would then put your audio out from your souce device (xbox, tuner,record player...etc.) to the input of the reciever. Every device should have a different input. From there you would just switch your input selection to what you would like to hear. Let me know if you need a bit more guidance and I will get more detailed. The RCA connection (Red and White) are your stereo leads or (left and right) You will need the yellow one for video..it is separate.
Jan 19, 2013 | Sony DAVHDX265 System
I am trying to install a Honeywell RTH2300B thermostat. I can't get the wiring. I have a red, blue orange, green, yellow, brown and white wire and B, O, G, Y, W, Not Used, R, and RC terminals. Can
what type of system are you wiring it to???? for general info b and o are used if heat pump system, g =fan (blower), Y =cooling (ac), W=heat, R and rc are 24v feed to stat, do not use rc if system does not have cooling. if it does and 24v is from one source then connect fed to r and install jumper between r and rc . you list wire colors you must identify where they are connected at other end.
Nov 16, 2012 | Heating & Cooling
RTH2310, want to install on at two wire system, i understand R to red W to white but this thermostat has a wire connecting the Rh and Rc. and cannot move the screws how do i install my R wire
Hello LEAVE the jumper wire in and connect the RED to either RH or RC with the jumper.You need the screw to loosen to secure the wire.If its impossible maybe solder the wire on to make it reliable.W=WHITE
Dec 28, 2010 | Honeywell Programmable Thermostat Heater
Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Nov 01, 2009 | Honeywell Electronic Programmable...
My husband just installed the Honeywell RTH2310 thermostat. The fan turns on, but the furnace does not. What's our next step? (It's a natural gas furnace and he made sure that it is on correct h/e setting....
need to make sure there is a jumper between RC and RH if the red wire is connected to the RC terminal the heat wont work you will need a jumper wire to tie the RC and RC together with the red wire.
Oct 20, 2009 | Honeywell Focus 6300B 5-2 Days...
Installing subs, how to use rc converter
from the rc converter i connected to the rear speakers taking both positive (left and right) to the positive on the factory speakers, then done the same with the negative (left and right) to the negative of the factory speakers. i connected with a quick connect. then from the converter to the amp using rc's. since my battery is in the trunk, the only wire i had to run through the car is the remote wire from the radio to my amp and then my subs to my amp.
May 14, 2009 | 2005 Chrysler 300
Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Jan 10, 2007 | Denon AVR-1706 Receiver
98 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
