Question about Denon Audio Players & Recorders
How to connect to speakers
Need guidance to connect system
    Sergeant:
  • 231 Answers
We have accidently given our speakers for our Technic se-hd 560 system to a charity shop. Please advise what to ask for to replace. Many thanks
Any radio shop will replace this speaker. Just give them make and serial number. Can you buy it back from the charity shop ?
Nov 27, 2014 | Cars & Trucks
When playing DVD all the audio is clear expcept words spoken by actors and is is buffled. How do I fix?
Make sure your Center speaker is enabled, defined to the system and working according to the manual.
See pages 18 and 19.
Then look at DVD Preferences on Page 37 and run those speaker tests and adjustments.
Mar 08, 2011 | JVC TH-C6 System
No sound from pc
though i need to know either the make n model of main/mother board u r using or the sound chip, to serve u better..
likely to b problem with driver, howevr, many times itz seen that the sound chip on the m/b is faulty..
often follows with software corruption/os failure..
i guess u r using a licensed n updated antivirus..
download, install n run microsoft kb890830
check with the following step(s)..
1) replace n see, if other speakers r running in ur pc..
2) connect ur speaker to other computer (anywhere), n see..
3) try download n install the audio driver..
4) remove unnecessary items from boot..download n install 'Startup Control Panel'..in here uncheck unimportant startup items..
OR 5) replace the RAM with a standby..
OR 6) reinstall os..
OR 7) disable audio device from the CMOS/BIOS..install a fresh PCI Audio Card n see..
[if u r at option 7, howevr, it works or not, probably itz for sure that the main/mother board is defective]..
at any point of time, u may contact me/us, in case u require any guidance..
if u r not a professional, try contact ur system admin/vendor....
Nov 05, 2009 | Labtec Spin 45 Computer Speakers
Pc internal speaker does't work-not on mute
it will be internal motherboard cabling problem connect your internal speaker wire on your boards or take guidance to any nearest hardware engineer.
May 04, 2009 | HP Compaq Presario SR1617CL PC Desktop
2005 acura rl radio on but no sound no audio at all
Hi........Boss
Please check you wairing system of your car, which is connected with the 4 speakers.
Thank you.
Feb 20, 2009 | 2005 Acura RL
Enquiry: Is it essential to have speakers that have a direct power lead. The computer in question is HPA6332 - 9500.
Page 17 provides guidance for connecting speakers to an HP A6332.
http://h10032.www1.hp.com/ctg/Manual/c00839729.pdf
This excerpt on page 17 can be clarified by adding "IF," before the sentence.
"NOTE: Speakers may be passive (no power button and no power cord) or active (power
button or power cord). Your computer supports only active (powered) speaker systems; the
speaker system must have its own power cord."
This is an excerpt from page 21
"Speaker types
Speakers may be included with the monitor (select models only) or are sold separately.
Refer to the product documentation for your speakers.
Your computer supports only an active (powered) speaker system. An active speaker
system must have its own power cord. A home audio system does not require active
speakers, because the receiver provides amplification."
Generally speaking, manufacturers offer many types of speakers for use with their computers. If the speakers that originally came with your computer had a extrernal power supply, then it would probably be best to use externally powered speakers.
I have seen many older computers and even some budget computers that use the sound card for amplification. Most modern sound cards are primarilly focused on sound processing, and not necessarilly amplification.
Its impossible to know whether your system requires powered or non-powered speakers because I have no way of knowing your computers specific configuration. However, I think it is safe to say, if you use externally powered speakers in either case, you should be ok.
If you call the manufacturer, or go to its web site, your original computer configuration can normally be provided if you provide its serial number.
Hope this helps - Good Luck!
Nov 04, 2008 | HP Computers & Internet
Am setting up a bose GSX 3-2-1 home theater
Need to know the TV connections. On newer TV's there RCA jack connection or ext speaker connections. Usually the external TV speaker connections hook to the woofer and the rest of the speakers are connected to the woofer. The woofer acts as the sound system for the rest of the speakers. With this method you need to mute the internal TV speakers by a swiich on the TV or internal TV setup menus and select ext speakers.
Jan 26, 2008 | Bose Cinemate Digital Home Theater System...
Kenwood KNA DV3200
IF there is no route guidance it is because the unit is not receiving VSS information from the vehicle.  Confirm that you are getting the VSS info from the correct source and or use Rostra Precision Control's cruise control guide to confirm your VSS wire.
Oct 12, 2007 | GPS
Whenever I turn receiver on, it turns off almost immediately
The amplifier blew out (probably shorted and damaged when wire was loose, and gave out under load). It won't be cheap to repair....
Sep 12, 2007 | JVC RX-D301S Receiver
29 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
