Question about Canon Pixma iP2700 InkJet Photo Printer
Bad printing quality
Printing quality is bad when i used both colors or black only. the lines is not complete and is blurry.
    New Friend:
  • 12 Answers
First off, Turn on your printer, on your PC/laptop go to Printers and Faxes (you haven't said which operating system you use)
Find your printer icon, right click on it, select Properties, locate and find Maintenance tab, click cleaning/deep cleaning.
When you don't use your printer for a while, you must clean the head/nozzle , that's why you have blurry print outs.
Posted on Apr 12, 2014
  • Khalil Bigtas
    Khalil Bigtas Apr 12, 2014
    I've done it already. however, the outcome was still the same.
  • Walt007 Apr 12, 2014
    Khalil, are you using the correct cartridge or is it one of supermarkets own brand?
ctf1800
  • 4402 Answers
SOURCE: printing in black "fuzzy"
have you replaced the ink art with a new one?
if you have time to replace the print head.
Posted on Dec 13, 2007
ctf1800
  • 4402 Answers
SOURCE: Bad quality printing from the black cartridge
Select the correct Media Type setting (Windows)Print an image from another source
Change the Print Quality Settings (Windows)
try these if they dont work time for print head replacement.,
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10236
Posted on Jan 09, 2008
old marine
  • 2131 Answers
SOURCE: Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Posted on Jul 26, 2008
  • 164 Answers
SOURCE: Bad color. Black text prints green, red comes out
You may want to use brand ink as its mixture is more reliable. However if you have changed cartridges frequently try cleaning the print heads.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Hope this helps. .
Posted on Feb 07, 2010
Testimonial: "Thank you for your EXCELLENT assistance! Your advice was thorough and your instructions sound easy to follow. THANKS!!"
ohms
  • 1879 Answers
SOURCE: Black ink is not comming out well when printing?
1. try printing from another program, if it comes out good, check your software settings.
2. check your printer driver settings or reinstall/update
3. use another printer cable
4. print from/using the printer's control panel, if the output is bad, it is already a hardware failure.
Posted on Mar 31, 2010
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    Print head is not printing seems to be clogged from non-use. Have tried test printing through several new cartridges and still not working. Can the old - dryed ink be cleaned off of the print heads?
    Hi, below is from the brother website for your model. Very common for the ink heads to become clogged /dry out. You probably have done this but here it is anyway. your print head is part of the machine, so it will need to be disassembled to clean it, That can be very difficult. Try the following anyway, it might help you. also, you could try using a Q-Tip wet with vinegar water to get under to the bottom of the print heads, if you can get the head to move off its dock and then unplug it when its moved over. anyway here is the Brother link info (without pictures-see the link above if you need the pictures)
    • Print a Print Quality Check Sheet.
      1. ress the Ink or Ink Management key on the control panel of the machine.
      2. Press the up or down arrow key to choose Test Print and press OK.
      3. Press the up or down arrow key to choose Print Quality and press OK.
      4. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to chooseNo for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press down the arrow key or 2 or "-" to chooseNo for color with the problem.
    8. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
      • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet
      • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times).
      • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times).
      Press Stop/Exit.
    Aug 29, 2010 | Brother MFC-5460CN InkJet Printer
    Toubleshooting and routine maintainance is what comes oout on myscreen
    Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
    http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
    How to improve print quality Cleaning the print head
    To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
    Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
    Caution
    Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
    1 Press Ink.
    2 Press or to select Cleaning.
    Press Menu/Set.
    3 Press or to select Black, Color or All.
    Press Menu/Set.
    The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
    Checking the print quality
    If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
    1 Press Ink.
    2 Press or to select Test Print.
    Press Menu/Set.
    3 Press or to select Print Quality.
    Press Menu/Set.
    4 Press Color Start.
    The MFC begins printing the Print Quality Check Sheet.
    5 Check the sheet to see if the quality is OK by following these steps:
    Color block quality check
    The LCD shows:
    6 Check the quality of the four color blocks on the sheet.
    7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
    OR
    If you can see missing short lines as shown below, press 2 (No).
    The LCD will ask you if the print quality is OK for black and three colors.
    OK Poor
    Is Quality OK?
    1.Yes 2.No
    Black OK?
    1.Yes 2.N
    8 Press 2 (No) for Black or three colors
    with a problem.
    The LCD shows:
    Press 1 (Yes). The MFC will start cleaning the print head.
    9 After cleaning is finished, press Color Start. The MFC will start
    printing the Print Quality Check Sheet again and then return to
    step 5.
    10 Press Stop/Exit.
    Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
    Prints blurry every other line with black color
    Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
    -press setup menu, then go to tools
    -select clean print cartridge and press ok
    -it will print a test page. If the printout is good, you can try printing again.
    I hope this helps.
    Regards,
    Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    It will not print black print information on paper, bad quality
    1.800.421.6699 call that number and select option 01 for prints missing black or color ink
    Jan 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Phote prints out faded and in black and pink only
    There are a number of single issues that can cause your problem in this case. The most common are listed below:
    1.) Color cartridge expended.
    2.) Print Paper selection incorrect.
    From your statement above. I would suggest it is both item 1 and 2. Since, we are doing this assistance via chat mail, I can't come to your aid and witness myself what the results are and what your settings are for the paper type.
    When you end up with a red hue over all over the print area the cause it usually a bad print head and selecting the wrong paper type.
    To answer you question then, Yes, replace your color cartridge. But, first, try this method below to clean your color cartridge bubble jets.
    When you go to print a job, always go into print setup or printer properties and choose the paper type as closely as you can to match the paper you are using.
    The print head manual cleaning is listed below, it is from Lexmark. Below that is a process to clean blurry and bad print results. Although this is not specifically the case in your problem. The process to achieve resolution will also correct any problem your machine may be having. Remember, I do believe you need a new color cartridge. You will know with certainty however when you clean the cartridge head. If you do not see, cyan, magenta and yellow lines upon cleaning, at all, ever, then those inks are depleted. Replace your ink cartridge and then do these steps below the head cleaning.
    Also, when ever you change a black or color cartridge you will want to run a print head alignment test and adjustment. There is enough of a difference in cartridges that this is quite necessary.
    Please do not hesitate to give me as much feedback as possible on any issues and results you discover. You can use the comment text area below to respond to these instructions and give me the results of your tests and procedures.
    Regards, Worldvet
    Cleaning procedure
    1. Remove the print cartridges.
    2. Moisten a clean, lint-free cloth with water.
    3. Gently hold the cloth against the nozzles for about three seconds, and then wipe in the direction shown below.
    4. Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe in the direction shown.
    5. With another clean section of the cloth, repeat steps 2 through 4 above.
    6. Allow the nozzles and contacts to dry completely.
    7. Reinsert the print cartridges.
    8. Print the document again.
    9. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
    To Resolve Print Quality Issues (below is for blurry lines, it will resolve many other issues too, so proceed after replacing your color ink cartridge if upon cleaning you see no ink coming out and the cartridge feels very light and makes little to no sound when you shake the cartridge.)
    Overview This article outlines various techniques for resolving a blurry print issue. Cleaning the print cartridge nozzles is necessary when:
    • Characters are not printing completely.
    • White dashes appear in graphics or printed text.
    • Print is smudged or too dark.
    • Vertical, straight lines are not smooth.
    • Colors on print jobs are faded, or they differ from the colors on the screen.
    Clean the Print Cartridge Nozzles using the Computer
      1. Load plain paper.
      2. Open the Lexmark Solution Center (go to Start, Programs, Lexmark XXXX Series, Lexmark Solution Center).
      3. From the Maintenance tab, click Clean to fix horizontal streaks.
      4. Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles.
      5. Print the document again to verify that print quality has improved.
      6. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
    Clean and Wick the Cartridge
    1. Try cleaning and wicking the cartridge to help improve the print quality. See this article for directions.
    2. When this step is complete, try to run the clean print nozzles (CPN) operation again.
    Auto Alignment · Align the print cartridges
    Align the print cartridges after installing them to improve print quality. To do this:
      2. Open the Lexmark Solution Center.
      3. From the Maintenance tab, click Align to fix blurry edges.
      4. Click Print. NOTE: Discard the page after it prints.
    User the Quality Settings in Print Properties
    Print Properties is the software that controls the printing function when the All-In-One is connected to a computer. You can change the settings in Print Properties based on the type of project you want to create. Do the following:
    1. With a document open, click File, Print.
    2. In the Print dialog, click the Properties (or Preferences, or Options, or Setup) button. The Print Properties screen appears.
      Click here for an enlarged view.
    3. Try changing the following settings to see if your print quality improves:
      Quality/Copies
      Quality/Speed
      Multiple Copies·Specify how the All-In-One should print several copies of a single print job: collated or uncollated.
      Print Color images in Black and White·Select this to print color images in black and white.
      Paper Setup
      Paper Type·Select the type of paper you are using, or allow the printer sensor to select the paper type for you.
      Paper Size·Select the size of the paper you are using, and specify whether or not you want to print borderless.
      Orientation·Specify how you want the document oriented on the printed page - portrait or landscape.
      Print Layout
      Layout·Select the print layout you require.
      Duplexing·Select this option when you want to print on both sides of the paper.
    Save Settings
    From the Save Settings menu, you can name and save the current Print Properties settings for future use. You can save up to five custom settings
    I Want To
    The I Want To menu appears when you open Print Properties. It contains a variety of task wizards·printing a banner, printing a poster, printing a photograph, printing an envelope, printing on both sides of the paper·to help you select the correct print settings for a project.
    Check the Media
    If the print is still blurry, try printing the same image on a different media brand/type: plain paper designed for use with inkjet printerscard stockgreeting cards, index cards, postcards, or photo cardscoated paperphoto or glossy papertransparenciesiron-on transfersbanner paper
    Use the Lexmark Photo Editor
    Try printing a higher quality image, or print an image from a different source.
    Dec 20, 2008 | Lexmark Z611 InkJet Photo Printer
    Unable to print BLACK
    The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time. Print the Print Quality Check Sheet and see if all colors are present:
      1. Press the Ink Management key.
      2. Use the up or down navigation key to select TEST PRINT.
      3. Press Set to confirm your choice.
      4. Use the up or down navigation key to select PRINT QUALITY.
      5. Press Set to confirm your choice. Press the Color(Colour) Start key to print the Test Sheet.
    If one or more of the colors is still missing from the printed page, cleaning the print head may resolve this problem. When cleaning the print head, you are given the option to clean BLACK ONLY, three colors at a time (CYAN, YELLOW, and MAGENTA), or all four colors at once. For this issue we recommend cleaning only the affected color. If more than one color is missing then select ALL. Follow the steps listed below to clean the print head:
    Cleaning the Print Head
    2. Use the up or down navigation key to select CLEANING.
    4. Use the up or down navigation key to select the color that is not printing
      -OR-
      Select ALL if more than one color is not printing.
    5. Press Set to confirm you choice.
    6. The machine should begin cleaning automatically, and the LCD will alternately show "CLEANING" and "PLEASE WAIT". When the machine completes its cleaning cycle, the LCD will display the date and time.
    7. Test by printing the "Print Quality Check Sheet":
    If one or more of the ink colors is still missing from the printed page, repeat the print head cleaning steps listed above up to 4 more times. After each cleaning, print the Print Quality Check Sheet to see if there is any improvement.
    I hope it helps!!!
    Dec 09, 2008 | Brother DCP 115C All-In-One InkJet Printer
    Streaks though the pages
    Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
    1. In the application you are printing from, click File , and then click Print .
    2. Make sure the printer is selected, and then click Properties .
    3. Select the Paper/Quality tab.
    4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
    Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
    2. Make sure the printer is selected and click Properties .
    3. Click the Color tab, and select Print Grayscale and High Quality .
    Step four: Clean the printheads If the print quality is still bad, clean the printheads.
    1. Make sure the printer is loaded with unused white paper.
    2. Open HP Solution Center .
    3. Click Settings , Print Settings , and then select Printer Toolbox .
    4. Click the Service Tab .
    5. Click Clean Printhead , and then click Clean .
    Step five: Align the printheads If the print quality is still bad, align the printheads.
    2. Open the printer Toolbox , and select the Printer Services tab.
    3. Click Align Printheads . The Align Printheads window opens. Click Align .
    4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
    Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
    2. Open the printer Toolbox and select the Printer Services tab.
    3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
    Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
    2. Press the Setup button.
    3. Press 1 and * simultaneously.
    4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
      • If the Black block has lines – replace the KY printhead.
      • If the Cyan block has lines – replace the MC printhead.
      • If the Magenta block has lines – replace the MC printhead.
      • If the Red block has lines – replace the KY printhead.
      • If the Green block has lines – replace the KY printhead.
    Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
    My copy prints come out blurry after changing ink cartiges
    Try this:
    Checking the print quality:
    1. Press the Ink or Ink Management key on the control panel.
    2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
    3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
    4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
    5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
    6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
      If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
      If you can see missing short lines, press 2 (NO) and go to Step 7.
    7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
    8. The display will then show START CLEANING? 1.YES 2. NO.
      Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
    9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
    10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
    Setting the Alignment:
    3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
    4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
    5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
    6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
      If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
    7. Press Stop/Exit.
      If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
      Thanks, Joe
    Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
    Nov 30, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
    Canon Pixma iP2700 InkJet Photo Printer Logo
    127 people viewed this question
    old marine
    old marine
