Question about La Pavoni Europiccola EPC-8 Espresso Machine
Dissasembling Europiccola Pavoni
The watertank/boilercistern does rotate a little visa the ground plate. Looking in it after removing the bottom plate doesn't make me any wiser??
  • 2 more comments
  • Piers Carter
    Piers Carter Jun 01, 2014
    have a look here very good site look at base repair
  • Piers Carter
  • Piers Carter
    Piers Carter Jun 07, 2014
    Ok I keep trying to put a link in to a site I found after googleing for hours If it doesn't come up try searching Dr Pavoni.
  • Piers Carter
    Addhttp://www.francescoceccarelli.eu/La_Pavoni/Faidate/fissaggio_base_eng.htm a Comment
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
The boiler is tightened down via a big brass or plasitc ring which is threaded look on the page linked below
Posted on Jan 03, 2015
mirran
  • 515 Answers
SOURCE: La Pavoni Professional, Chrome, 16 cup capacity Europiccola
You have to take a screwdriver and try to bend up the platic, be careful so you not break it.
Posted on Aug 20, 2008
z34aga
  • 137 Answers
SOURCE: adding pressure gauge to Pavoni Europiccola
  1. in the boiler water is heated and presured up to 1.5 bar
  2. when water gets in lever and non return valve closes becouse you press the lever down, your energy is used to get high pressure, it should be frpm 7 up to 9 bar.
  3. SOLUTION==if you search way for modifying, you must consider that you must pump directly to group, not to boiler. in this case water will be cold (becouse comes from pump). you will need boiler in boiler to heat the water wich comes from pump before it gets to group. this is bit more complicated than you thought may bee but it is only solution.
Posted on Mar 30, 2009
EsWorld
  • 1618 Answers
SOURCE: First Cup Is Cold From La Pavoni Europiccola
If the machine works great after the first cup then it is possible that the heat for your first espresso went to heating the portafilter or the cup used to brew into, try warming the portafilter first by running some hot water through it first.
Posted on May 31, 2009
LaPavoniBoy
  • 36 Answers
SOURCE: My La Pavoni Europiccola
Hi there, i am a domestic espresso machine engineer based in Glasgow and i specialise in La Pavoni machines. If you could get in touch with me at my e-mail address (coffeeservice@live.com) i will be able to help you but i will require some info from you about what happened. It sounds like a pressure problem or the thermostat has gone allowing the water to over boil and build up too much pressure. Pressurestat is most probable i reckon. If you give me an idea of what happened i will be able to help you. I work alongside the UK's lead supplier of La Pavoni spairs so have all bits in stock. E-mail me or give me a buzz on 0141 425 1083 and i can sort you out.
David Martin
The Domestic Coffee Service
Posted on Jul 23, 2009
LaPavoniBoy
  • 36 Answers
SOURCE: There is water leakage on my La Pavoni Europiccola machine
I am a domestic coffee machine engineer based in Glasgow, Scotland and i service, repair and refurbish these machines on a daily basis. You will probably find that the gaskets which are holding the sightglass in place are completely solid and resemble a hard plastic like gasket. There will definately be gaskets there as if not the sightglass would rattle about and the water would pour straight out. It depends on which sight glass nuts you have but if they are the clear plastic nuts you will find either black, white or clear gaskets underneath and if the nuts are metal then you should see brass washers first and then the gaskets underneath the washers. These are easily replaced and can be purchased from our website www.theespressoshop.co.uk I hope this helps and if you have any further questions or queries then please do not hesitate to get in touch at domesticespresso@live.com
Posted on Jun 02, 2010
Heating by rollers not rotating
I have had the same thing happen to me and it pertained to the rollers having something clogged in them. Remove bottom plate and take a look. Make sure you unplug your machine prior to looking. Thank you Alan and please leave feedback.
Jul 13, 2016 | Vacuums
The water light comes on and stops the machine from working even if water is full
There's a float (with a small magnet) in the watertank. This float should go up when the tank is filled with water.
So the float can be stuck in the bottom position, or the sensor doesn't work.
You can test the sensor.
  • Take the left cover off: two screws on the back, slide the cover backwards, then lift the bottom up and pull the toppart out downwards.
  • On the main board there's a plug right at the top, that's the cable from the watertank-sensor. With the watertank removed it shouldn't conduct.
  • Now fill the watertank, check whether the float is going up, put the tank back in the machine.
  • The sensor switch should be conducting now. It it is, then the problem is in the control board.
Hope this helps!
May 28, 2015 | DeLonghi Esclusivo Magnifica ESAM3300...
I have an Amana (ABB2524DES) bottom freezer fridge. The fridge is not cooling but the freezer seems fine. I just took the back cover off and the fan is working. I cleaned everything and put it back...
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 30, 2011 | Amana ABB2524DE Bottom Freezer...
The brush is not rotating
The belt is broken.Turn the machine so you are looking at the brush.The plate on the bottom of the vacuum needs to come off.Most are screwed,some plates just pop on.Remove the plate and then the brush.The belt fits in a groove on the brush.The other end fits on a small wheel about 6 inches back from the brush.
May 18, 2011 | Dyson Vacuums
I've got a problem with my Saeco Vienna Digital. It says that I've got to fill the watertank and ventilate. But the watertank is filled, that little 'thing' in the corner of the watertank is still going up...
Check the end of the steam wand it might be blocked, if it is not, then remove the steam wand and check the top there is a small teflon insert (this part is in some models) remove insert and toss. If that does not solve problem then machine needs to be descaled.
Jan 12, 2010 | Saeco Vienna Digital Coffee Maker,...
Error E18, the zoom is blocked
Hi
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
There are six screws holding the metal frame of the camera body together, two on each side, and two on the bottom. Remove all screws, pop the strap-hook plate (sorry, probably not the most technical term there), then gently lift the front plate off by pulling up from the bottom, and remove the back plate in the same fashion. These should come off relatively easily. This is what the camera should look like as you remove the plates:
img-5340-thumb.jpg?w=324&h=217
  1. Now, looking from the top of the camera, you should see a small motor on the left side, as shown below (it’s beneath the cable with a “22” written on it):
    img-5346-thumb.jpg?w=324&h=217
  2. Take your screwdriver (or another small instrument) and gently try to rotate the plastic piece attached to the motor on the left side, as shown below:
    img-5359-thumb.jpg?w=324&h=217
  3. At this point, try placing the battery back in the camera (if you have removed it), turn the camera to one of the capture modes, and press the power button. If all went well, your lens should now be able to extend and retract properly.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 26, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Need help on to set up belt for shampoo for
Lift the light bulb housing up and you will find a latch that will rotate to release the front agitator housing and remove it from the machine. On the bottom of that housing, there are two latches that secure the bottom plate that covers the roller. Remove the plate and the roller will come out. Be sure to notice that the roller has a magnet at one end that lines up with the indicator that shows you when the roller is turning - it's the little green light that glows while you are vacuuming. The roller needs to go back in the same way it came out. O.K. Take your new belt and position it around the middle of the roller and drop the roller back into place and replace the bottom plate. On the front of the housing, there is a big square "knob" and you can rotate that piece. If you look inside the hole on the other side of the agitator housing, you will see that there is an arm that moves with the square knob. The end of this arm will catch the belt and with a little effort, the knob will rotate and lift the belt into position for replacing the housing back on to the machine. once you have the housing back on the machine and secure, you rotate the square knob back around and the belt will sit down on the drive shaft. If you look at the top of the agitator housing just above where the knob is, you will see a red and a green arrow which indicate which way the knob turns to do the "remove" belt or "replace" belt. I hope this helps. Once you do it properly, it actually is quite easy.
Mar 07, 2009 | Vacuums
Belt replacement
Rating
Jan 25, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby vaccum ultimate G
Jan 12, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Watertank leaking
Miele prices are a little steep!
The parts for these machines are made by Saeco, if you are prepared to do a little research and looking at exploded parts diagrams you may save a lot of money by matching a part, start by trying here:
www.partsguru.com
Oct 19, 2007 | Miele CVA2660 Stainless Steel Coffee Maker
La Pavoni Europiccola EPC-8 Espresso Machine Logo
95 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
