Question about La Pavoni Europiccola EPC-8 Espresso Machine
Dissasembling Pavoni Europiccola - La Pavoni Europiccola EPC-8 Espresso Machine
    Problem Solver:
  • 7 Answers
Google "Europicola repairs" (note spelling, only one C!) and you will find lots of videos and other directions for repairing these machines. They are very simple in design and mostly fairly easy to repair.
Posted on Jul 30, 2014
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
Try looking at this site its really good helped me do various repairs to my La Pavoni Pro
http://www.francescoceccarelli.eu/lapavoni_faidate_eng.htm
all the best P
Posted on Jun 01, 2014
mirran
  • 515 Answers
SOURCE: La Pavoni Professional, Chrome, 16 cup capacity Europiccola
You have to take a screwdriver and try to bend up the platic, be careful so you not break it.
Posted on Aug 20, 2008
z34aga
  • 137 Answers
SOURCE: adding pressure gauge to Pavoni Europiccola
  1. in the boiler water is heated and presured up to 1.5 bar
  2. when water gets in lever and non return valve closes becouse you press the lever down, your energy is used to get high pressure, it should be frpm 7 up to 9 bar.
  3. SOLUTION==if you search way for modifying, you must consider that you must pump directly to group, not to boiler. in this case water will be cold (becouse comes from pump). you will need boiler in boiler to heat the water wich comes from pump before it gets to group. this is bit more complicated than you thought may bee but it is only solution.
Posted on Mar 30, 2009
EsWorld
  • 1618 Answers
SOURCE: First Cup Is Cold From La Pavoni Europiccola
If the machine works great after the first cup then it is possible that the heat for your first espresso went to heating the portafilter or the cup used to brew into, try warming the portafilter first by running some hot water through it first.
Posted on May 31, 2009
LaPavoniBoy
  • 36 Answers
SOURCE: My La Pavoni Europiccola
Hi there, i am a domestic espresso machine engineer based in Glasgow and i specialise in La Pavoni machines. If you could get in touch with me at my e-mail address (coffeeservice@live.com) i will be able to help you but i will require some info from you about what happened. It sounds like a pressure problem or the thermostat has gone allowing the water to over boil and build up too much pressure. Pressurestat is most probable i reckon. If you give me an idea of what happened i will be able to help you. I work alongside the UK's lead supplier of La Pavoni spairs so have all bits in stock. E-mail me or give me a buzz on 0141 425 1083 and i can sort you out.
David Martin
The Domestic Coffee Service
Posted on Jul 23, 2009
  • 100 Answers
SOURCE: my la pavoni europiccola will not pull water
Machine needs to be rebuilt with new gaskets. We do this repair
www.dolcevitaespresso.com
Posted on Feb 15, 2011
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
Dissasembling Europiccola Pavoni
The boiler is tightened down via a big brass or plasitc ring which is threaded look on the page linked below
Apr 12, 2014 | La Pavoni Europiccola EPC-8 Espresso...
Fuse keeps blowing La Pavoni Europiccola 1996
Hi That's a short it's all it could be isn't it. Plug? lead? water or damp in the base? try slipping the black base off you will need a security bit to get it off or at least mine does its a t bit with a hole in the middle I think, have a look for water that might be shorting it out also try it in another socket , you never know.
Best of luck.
Feb 28, 2014 | La Pavoni Coffee Makers & Espresso...
Water leakage through grounds when lever is raised on my La Pavoni Europiccola.
Hi your grind is to course and or your tamp is to loose. Even with the right grind and tamp water will filter down through the puck eventually.
all the best
Dec 20, 2013 | La Pavoni Europiccola EPC-8 Espresso...
I have an europiccola from the 79s that i got off the internet. I can't get it to heat up. I know the fuse is good, the switch is good (i check both) so is the only think the heating coils? If so where can...
If you check the coil with your ohms meter and get no reading then you might be able to find one from crossroads espresso they are the biggest Pavoni dealer 15413444600.
Apr 30, 2010 | La Pavoni Europiccola EPC-8 Espresso...
Apr 09, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Hi there, Where can i buy a replacement heating element for the Europiccola Copper-Brass Espresso machine? V220 W1000
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Feb 22, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Adding pressure gauge to Pavoni Europiccola
Feb 20, 2009 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni Europiccola EPC-8 Espresso Machine Logo
Top La Pavoni Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
noel
noel
matt
matt
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
