Question about Celestion S10 Subwoofer
How do I set up a Celestion S10 Subwoofer...
Hi, I have a Celestion S10 sub woofer with avp 305 speaker. I am using this device form a sony dvd player of which the speakers are plugged into. What settings do I set on the subwoofer as I have no manual, and line in, highpass output left, input level even what voltage do I use 230 or 115v is confusing . All I can say is I get a deep vibration sound from the sub woofer and when I adjust the phase or frequency crossover I am scared of doing permanent damage to the system.
  • Celestion Master
  • 3,320 Answers
OK
Voltage is relevant to where you live in the world. America it's 110. Europe mostly 220.
What you're asking is a very deep and complicated question.
I'm attaching a link with some articles.
What I suggest is that you find an upper end audio store and ask a 20 audio head to set up your system for you. Subwoofer Setup and Calibration for Best Bass
Posted on Apr 13, 2014
2 Suggested Answers
  • 17 Answers
SOURCE: pc connection
What you are proposing will not work.
You can EITHER use the Line inputs OR high level speaker inputs.
Using the line inputs, your L&R line level signals pass through the sub on their way to a stereo amp, then speakers.
Using the Speaker inputs, your L & R speaker cables connect from your amp (or PC speaker outputs) to the "Speaker input" terminals. The "Speaker output" terminals then connect to your speakers.
Posted on May 19, 2010
Hello Guys,Can you please help? can I replace the sub woofer on my sony home theatre system DAV-DZ231 with a Celestion sub woofer s10
Presumably, the Celestion subwoofer is self-powered in which case it would connect to an RCA subwoofer output on your Sony system if there is one.
Oct 30, 2014 | Audio Players & Recorders
My celestion s20 subwoofer won't play if i hook it up to sub out on receiver.but will play if i run a regular speaker wire to it. I know sub out is working on receiver.
Tell your source (receiver???) that it has a sub and set it up to feed LFE out of that RCA jack.
Prove your sub pre-out works. Or send something like FM on Tape Out to the sub and see how that works out.
How did you hook a speaker wire to this model of powered sub? What was on the other end of that speaker wire? It's not designed for speaker level input.
Jan 28, 2011 | Celestion S20 Subwoofer
Cannot get the sub woofer to work.
Now tell the NAD you have a subwoofer. Page 15, Figure 13, etc. and Page 18 - 19.
Mar 05, 2010 | NAD T770 Receiver
Sub is clicking and sound is muffled
big red
get a new rca cable and clean out the rca s from the reciever and sub
Oct 21, 2009 | Celestion S10 Subwoofer
Auto/on switch
unplug it when your not in use,,,
May 12, 2009 | Celestion S10 Subwoofer
I can't get bass thru the spkrs
So when you aren't using the sub woofer there's not enough bass, so you need more out of the other speakers. Chances are the front speakers are set to "small" in the receivers menu, change it to "large"if your front speakers have a 6 inch woofer or larger. Note: If you leave the sub on, the input signal to it will be greatly reduced when the speakers are set to "large". Hope this helps.
Feb 12, 2009 | Sony Audio Players & Recorders
Clestion S10 Sub not working
Instead of connecting it to the sub output, try it on the L or R output of your amp.
This will eliminate the Denon.
If this fails, you need to test the loudspeaker driver unit whilst disconnected from the sub amp. Use a 1.5v cell (AA or bigger) connect using croc leads to the speaker's terminals. If the speaker is OK, you should hear a click. If you hear nothing, the speaker unit is faulty.
Jan 25, 2009 | Celestion S10 Subwoofer
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Celestion S10 Subwoofer Logo
451 people viewed this question
Top Celestion Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Rankin
Richard Lindsey ...
Are you a Celestion Audio Player and Recorder Expert? Answer questions, earn points and help others
