Question about Pioneer Audio Players & Recorders
Pioneer hometeatre overtemp - Pioneer Audio Players & Recorders
WHEN FRYER HEATS UP THEN IS LOADED TEMP SEEMS TO FALL AND HAS TO BE RESET
If you manually reset by pressing overtemp thermostat, then check your operating thermostat.. maybe over heating.. if so replace thermostat.. if pilot cuts out completely prematurely without reaching set temp then replace overtemp cut out thermostat as it is faulty.
Cheers
Mar 22, 2012 | Pitco Frialator SG14 Deep Fryer
A/T oil temp indicator light came on while driving? Would drive ok but, starting after stopping, the care acted as if I was not getting enough gas or engery?
The transmission is slipping. Problem could be as simple as the transmission being low on fluid. Check this first. If that's not the problem, it should be taken to a shop for service.
Charlie
Jan 11, 2011 | 1999 Honda Passport
Overtemp
The cooling fan is probably not working. Unit will overheat. Check the fan to see if it run continuously with no scraping noise with the UPS turned "ON". If the fan does not run, open the case and replace the fan.
Jan 19, 2010 | Powerware 9120 UPS System
Engine overtemp
check coolant level
Oct 06, 2009 | 2002 Volvo S80
I FIND THE ERROR 010-320
That's a fuser overtemp fault, meaning your fuser either has a peice of paper jammed up in the fuser or the thermistor is blown (it acts like a fuse during an overtemp indication). You'll prpbably need to replace the fuser unit if it's not a simple jam.
Aug 20, 2009 | Xerox Office Equipment & Supplies
Mdg5500aww no heat / flame.
Yes, that open switch is the high limit thermostat. this will shutdown the unit and prevent it from heating. you must replace the open switch(thermostat) asap and, replace the thermal fuse as well.
Jul 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My au Falcon teperature light comes on about a minute after the engine is started, the temperature gauge shows low temperature, the radiator is not boiling, I have taken the temperature sender unit out of...
The low water level sensor is in the overflow bottle, not the overtemp sensor.
The overtemp sensor will be on the motor somewhere.
To check you have the right sensor- short the sensor to ground and observe the overtemp light operation.
You likely have a faulty over temperature switch sensor.
Jun 06, 2009 | 2006 Ford Taurus
Termal overtemp LED light on, welder not working, not overheated
interconnecting ribbon cable between circuit boards was not properly seated in receptacle
Mar 30, 2009 | Lincoln Welding Tools
Dryer will not fire
You have a thermal overtemp sensor that has failed, they are located in maybe two spots, but the diagram on the dryer should show you where they are.
Most can be jumped over with a jumper wire, some are resistive devices that send back a signal based on changing temp and resistance, but most can simply be jumper across from one side to the other, and if stays on, there is your problem, for a gas valve to fire, and then go off, it is either a thermocouple device with pilot, or one of those overtemp devices I mentioned. If the valve was bad it would not light at all, so it is one of those devices not the timer, not the board, not the anything it is an overtemp or thermocouple device.
Will
Dec 16, 2008 | Roper RGX4634KQ Gas Dryer
Mico only heats 4 to 6 minutes
many microwaves require x amount of clearance for exhaust heat, is it installed with the proper clearances?
it is one, not venting and tripping the overtemp,
two, the overtemp module is bad, or the board receiving the signal is bad
Nov 12, 2008 | Microwave Ovens
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
