Question about Plumbing
How to fit a dual flush - Plumbing
How to remove button mechanism on1984 carom a dual flush cistern to replace flush pipe rubber ?
normally corma cister controls are just a clip in arrangement
the bridge that holds the controls press fits into the front and back of the tank walls
lift the whole assembly out then do the repair
Dec 04, 2016 | Home
To short of flush
Take the top off the tank and look at the water height. Adjust the float valve to raise the water to the line on the back of the tank. There is usually a little screw.
If the tank is already high, try holding the flush lever down. Newer tanks are dual flush, which a short flush with a quick press and release (for having a wee), and a long flush holding the handle down for ... well you get the picture :>)
Jun 30, 2015 | Plumbing
Fluidmaster Dual Flush Valve S2DBL won't flush.
Fluidmaster S2DBL Dual flush valve - would not flush
The dual flush wouldn't work at all. So I slid the lid off part B (lever mounting base) and found the ball end of flush cable was not in the mating hole on lever arm. With needle nose pliers I pulled and pushed the ball into the hole and slide lid back on till it snapped. Snapped B to C (handle) - problem solved!
RAP
Jan 29, 2012 | Home
Despite fitting a new washer kit to an old style caroma dual flush/float system stop valve..water is still seeping into tank....even if i plug the inlet nozzle with my finger which yu would think would be...
I suppose you're talking about a toilet. One likely issue is the flapper valve ( if this has one). If no flapper then check whatever sealing mechanism is used to prevent water from entering the bowl when idle. Clean the sealing surfaces good. Make certain they are properly aligned.
Sep 01, 2017 | Caroma 270W-RF Reflection Round Front...
Buttons on our concealed dual flush cistern have stuck in, water constantly running into pan?
the ring where the buttons are should unscrew and the full unit should pull out,if that dos,nt stop the water try to gently pull the plunger up, if that stops it push the plunger back in to flush toilet,see if plunger returns to normal position and water stops, if that dos,nt work have it checked out by aservce engineer.
Jul 08, 2011 | Plumbing
Have fitted new fluidmaster flush valve, has a dual flush button operation but water constantly dripping down bowl so fill valve activates sporadically to maintain water level. how can i stop water...
Flapper not seating properly,either get new flapper or try a old trick i've used shut off water to tank and drain tank then add hot water to tank and let set for a while sometimes that will soften and seat flapper it's worth a try it's free.
Jun 08, 2011 | Fluidmaster & Fits-All Faucet Connector
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
How do I get the lid off a stylus toilet cistem
Solution I received " lever up the two flushing buttons with a fine blade screwdriver.
They may be a push fit on two plastic posts. Once off, they reveal a screw between them. Release this to remove the cistern lid. Make a note of the position of the buttons as they only fit one way round."
Feb 07, 2010 | Caroma 270W-RF Reflection Round Front...
Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
Plumbing Logo
42 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
