Question about Tanaka 35cc Pull Start Bladez Scooters
Tune bladez carburetor
How to tune 35cc bladez gas scooter
What is the ratio of gas to oil for a 35cc engine
Mix 3.2 ounces of Poulan 2-cycle air cooled engine oil to one gallon of fresh unleaded gasoline to obtain the recommended 40:1 fuel to oil ratio.
Over a period of time oil will separate from gasoline. To properly insure oil and gas mixture, I recommend thoroughly shaking your oil and gas mixture before refueling your unit.
If the saw is to be stored for longer than 30 days - drain the fuel tank, re-tighten the gas cap, and start the unit and let it run until it stops.
Jun 09, 2014 | Poulan Predator 35cc P3516pr Chainsaw...
Air screw adjustment
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.basic carburettor adjustment tuning 4 stroke and how it works
Two Stroke Scooter ATV Carburetor Settings And Adjustments 2of4 Idle Speed...
Scooter Carburetor Idle Adjust
Scooter Moped Carburetor Adjustment
50cc GET Carburetor Basic Tuning
Dec 07, 2013 | Bajaj Motorcycles
Scooter carb adjustment
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
How to tune carburetor in GY6 chinese scooter 150 or 50 cc
GY6 Enricher Automatic Choke Operation Testing
150cc GY6 Carburetor
Jun 30, 2013 | Benelli Motorcycles
Looking for a bladez DKS200 mobility scooter battery case?
http://www.bladezscooters.com/
http://www.monsterscooterparts.com/
Unlikely some other manufacturer's box will fit, if only because the circuit connecter is built into the pack.
May 03, 2012 | Health & Beauty
I have bladez moby that im being able to start but not to keep running, i used the ratio of 30:1 oil mix im not sure if its ok
Ok sorry you havent had an answer yet lol , here it is , i had this same issue . All you have to do is take the plastic cover off of the motor , and once its off pull the throttle ( with scooter off ) and you will see where it leades to . Where it leads to there is a screw which can be tightened to increase its motor stength / use . So tighten it , but only a little bit , if tightened to much the scooter will go without you pulling the throttle , so a 2-3 twists on a screw driver should do it. Once done , start your scooter up , and it should run great !
Dec 17, 2009 | Tanaka 35cc Piston Kit Bladez Moby...
Config of gas lined Mc Callogh chiansaw 3200
What little fuel system detail there is can be found here:
IPL (Chinese Mac, exploded parts list)
https://www.dixiesales.com/ipl/327/Chainsaws_32cc-35cc.pdf
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank. HTH
Lou
Oct 07, 2009 | Garden
WILL NOT IDLE
vaccuum leak, or idle adjustment screw maladjusted.
Sep 28, 2009 | Tanaka 35cc Piston Kit Bladez Moby...
How do I change the clutch belt on my BladeZ Moby motorized foot scooter (25CC)? Do you have any instruciton manual type pictures as I can't download any from the manufacturer?
there are 4 bolts that hold the engine in place on the left side of scooter when your looking straight towards the bars
then there are 3 more bolts below those tak em all all be carefull not to loose the small spacers behind the large ons there hard to notice but they are there
slip you belt over both pulleys and reasemble using the 2adjustment screws that attach to the big pulley on bottom until the belt is 110 & straight and has a little bit of play abotu half in or so should be fine you dont wat too much other wise it will break if you hit a bump or whatever an if its too loose wellit will slip as you might know
Jul 15, 2009 | Bladez 320-5M/25 Clutch Belt for BladeZ...
Tanaka 35cc Pull Start Bladez  Scooters Logo
14 people viewed this question
Top Tanaka Toys Experts
ray gallant
Are you a Tanaka Toy Expert? Answer questions, earn points and help others
