Whirlpool awm 1011
The machines is stop work with FA problem what is mean
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
Coldcut
  • 1554 Answers
SOURCE: Whirlpool AWM 8103/1 error FP
it looks like you have a clog filter or pump issue.
take a look at this forum
http://www.howtomendit.com/answers.php?id=53072
Posted on Feb 25, 2008
XboxModifier
  • 123 Answers
SOURCE: Whirlpool AWM 8143
Hi
Is definatly FA?
Posted on Mar 07, 2008
  • 6 Answers
SOURCE: F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
Posted on Jul 16, 2008
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
Whirlpool awm 8125 fault code F09 followed by FA
The drain pump runs constantly in an effort to drain the water. Unplug the washer and, if the washer is overfilled, check the water inlet valve assembly for proper shut-off of water flow. If the water inlet valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water-level pressure switch.
Dec 16, 2013 | Whirlpool AWM8143 Front Load Washer
Whirlpool awm 9000 I bought a used Whirlpool
The error code F/H for this machine means that the drain pump is blocked. Look at your manual for how to access the drain pump and clean it out. This will resolve your issue.
Oct 18, 2013 | Washing Machines
Hi. I have a Whirlpool 6th sense front loader 11kg washing machine (AWM 1008). After some very cold weather I now have an error code of FA. Do you know what this means and what I need to do? Thanks
Solution from a previous post i found for you.
  • Check the MCU
Most of the solutions i found for this same error were very similar. If all else fails read the manual or get a new washer when possible.
Feb 17, 2012 | Whirlpool Washing Machines
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
Sep 19, 2009 | Whirlpool Washing Machines
F 19 error on Whirlpool AWM 8085
F15 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit to check wire harness connections to the motor, MCU, and Central Control Unit (CCU).
Check the drive belt and reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor and check the drive motor for powered rotations.
Replace failed component.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 01, 2008 | Whirlpool AWM8163 Front Load Washer
Feb 24, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
