Question about Hoover DYN8163D8X White 600 mm Washer Front Loading, 8kg, A Energy Rating
Spinning Often does not spin a small load
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 80 Answers
This will probably be due to Out Of Balance, if the wash load is unbalanced (not enough or too much washing) the machine will not run to maximum spin speed to prevent possible damage
Posted on Apr 13, 2014
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Wont finish a small load. Gets to 4 minutes and
With a small load, the machine will have a difficult, if not impossible job of balancing the load. A bigger load will help. Another thing you can do is to use a low spin speed. If you wish to spin it out faster, just turn the machine back on after it has finished a cycle on the low spin speed and just push the spin speed button without selecting a cycle. You can touch the spin speed button until it shows the next higher spin speed, then push the start button and the machine will not fill with any water, it will just pump and spin. (about 14 minutes) This generally works, because you have spun most of the water out at a lower spin speed, and now the washer is able to reach the next higher spin speed as the load is not as unbalanced as it was before the low speed spin.
Nov 17, 2009 | LG WM0642H Front Load
GE washer model #wle4000b1ww won't spin
This is joyce
You have a bad belt it wont pull the load.
thanks,
joyce
Feb 04, 2009 | GE WPRB9220D Top Load Washer
Won't spin heavy loads
you need a new transmission it will slowly get worse until it stops working
Dec 23, 2008 | Whirlpool LSN1000LW Top Load Washer
HELLO WE HAVE A NEC WASHING MACHINE AND IT HAS STARTED TO ONLY SPIN LARGE LOADS OF WASHING IF THERE IS A SMALL LOAD IN THE MACHINE IT GETS UNBALANCED AND WILL NOT SPIN EVEN WHEN WE MOVE IT AROUND IN THE...
FRONT LOAD MACHINES ,WE DO NOT RECOMEND WASHING SMALL LOADS IN FRONTLOAD WILL NOT CLEAN CLOTHES PROPERLY,, ALL FRONT LOAD MAKE SAME NOISE WILL TRYING TO START SPIN CYCLE
Nov 27, 2008 | Washing Machines
My top load whirpool washing machine leaks during spin cycle.
it only does it on the small load? does the water drain out before it goes into spin?
Nov 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Final Spin
could be a clogged water pump. check the filter/pump for dirt and small items, socks, pins, coins,
tnx 4 using fixya,
drcool
Oct 11, 2008 | GE WBSE3120B Top Load Washer
Will not spin out heavy loads, stated by not balancing 2 mos ago
the transmission is shot after 20 loads a week for 4 and a half years
Oct 03, 2008 | Maytag PAV2300 Top Load Washer
New machine, manual says run a spin cycle, can't figure it out
make sure you remove all the shipping bolts per installation instructions then rock washer with hand and screw legs down till it doesn't rock then load an go call me back if any problems
Dec 30, 2007 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Hoover DYN8163D8X White 600 mm Washer Front Loading, 8kg, A Energy Rating Logo
71 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
