Question about Vehicle Parts & Accessories
1993 ford explorer doesnt start and battery and starter are good
As above
    Habit-Forming:
  • 55 Answers
If it does not start but you hear a clicking noise, jump the solenoid. If the engine turns over, replace the starter solenoid. also, check the main fuse dist box for big fuses blown.
Posted on Sep 26, 2014
My 92 explorer will not start when i turn the key i only get a click what could it be?
Either the battery is low on charge, or the starter is going bad. The battery is low on charge is the more likely cause in the winter months.
Also, the battery could be bad and is in need of replacement, assuming that it can be charged to 12 v or above.
The CCA may be low on the battery.
Good luck on this repair.
Dec 10, 2010 | 1992 Ford Explorer
I have a 1993 Ford Explorer. I have tested the starter and put a new solenoid on it. The battery has also been tested good. But when I try to start it all I get is a click.
try replacing the starter sokinoind costs 16 dollars and i conneted to the positive side of the battery ahs two battery wires connected to it and has one small wire wih two bolts that holds it on, and hard to change.takes about 5 minutes if that does nt fis it you have a problrm with the ingtion switch or the starter.
Jan 11, 2010 | 1993 Ford Explorer Limited
Car wont start, acts like battery is dead. battery shows full charge. full lights, buzzers, etc. put it on charger-didnt start...cleaned cable connections-didnt start...tried to jump with truck-didnt...
Check the battery +12v power connection to the starter is in good order,
Check the ground connection between the battery negative and the engine/starter motor is robust and intact.
If no problem with above, replace the starter motor.
Oct 10, 2009 | 1993 Ford Tempo
93 Ford Explorer Starter won't disengage from Fly Wheel
My ford f150 did the same thing, so I put the old starter solenoid back in( the one by the battery) and it cured the problem.
Come to find out, the after market relays aren't rated right, to get a good one, and the right one, you have to spend more and get it at a dealer.
Aug 18, 2009 | 1993 Ford Explorer Limited
Locating the starter in a 1993 ford explorer
it will be bolted around the bellhousing /gearbox area ,try a good battery off of another car first no jump leads .a battery may appear good with volts and all that but reserve amperage to turn the engine over is another matter
Jun 29, 2009 | 1993 Ford Explorer Limited
Starter/solenoid prob?
Replace the MAF sensor. The starter is overheating due to cranking excessively. It has noyhing to do with the engine staying running. The MAF sensor is located as the first sensor out of air cleaner. It controls the fuel. Good luck and have a safe trip.
Jun 18, 2009 | 1993 Ford Explorer Limited
Starter relay connections
if your starter engages but wont spin check to make sure the starter housing is making good contact on the bell housing or it wont ground out
Jul 07, 2008 | 1993 Ford Explorer Limited
Vehicle Parts & Accessories Logo
42 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
