Question about Health & Beauty
How do I know if my babyliss 7052BU is fully charged?
Babyliss pro needs a new cord
un screw it, then take from the base cut where broken and afix the points to there positive and vegative,then seal the whole device together......happy days
Sep 10, 2016 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
Babyliss instructions
Manuals here: http://www.fixdevice.org/manuals/brand/babyliss.html
Faq here: http://www.babyliss.eu/support/
I'd give you a better answer if you had more details in your question. I'd need to know specifically what product.
Aug 30, 2014 | Health & Beauty
I overcharged my babyliss grooming kit now it won't work
You will have to get new batteries. In Greece, there are specialist battery shops that supply or charge batteries for every possible use. One of these shops replaced my batteries for 8 euros and now my hair trimmer is as good as new again. The trimmer appears to take two common AA sized rechargeable batteries, so you should be able to change the batteries yourself.
Jul 01, 2014 | BaByliss 7053U Beard Trimmer
Need replacement foils for model 8667BU as mine is broken
hi my foil babyliss machine was broken how can iget new foil for model 5667bu
Jul 09, 2011 | BaByliss 8667BU
I have lost the charger for my Babyliss 7053u, where can I find a new one?
A new kit is fairly cheap: http://www.amazon.co.uk/BaByliss-Men-7053U-Over-Grooming/dp/B002FGTJ0O
I couldn't find just the charger anywhere... I would recommend just buying a new kit.
Apr 21, 2011 | BaByliss 7053U Beard Trimmer
My babyliss 789ou has lost the ability to set adjustment,this happened after travelling
This commonly happens to travelers. The voltage of electrical outlets differ depending on where you travel. Shavers bought in one country are specifically designed to handle the outlets of that country but plugging into a potentially higher output outlet you blow out the motor of your shaver which it seems like you did. The only real solution would be buying a new shaver. It had nothing to do with the shaver itself, simply a mix-up in charging the battery which caused the motor to overheat.
-Jord
Feb 28, 2011 | BaByliss Health & Beauty
On my babyliss type S47b, special screwdriver???
The screw may be triangular, or Torx (star pattern), or even 'pin-in-Torx', which all require special tools. They do it to prevent people from opening them up. But you can buy the tools, and for triangular screws I ground an old screwdriver down to match the shape!
Those screws are called 'Tamper Proof' or 'Tamper Resistant'. If you google those you'll find tool sets that will open dang near anything.
Mar 19, 2010 | BaByliss PRO Nano Titanium Hair Dryer
My forfex clippers won't hold a charge
How old are the clippers? Babyliss have a one year warranty on all their electrical goods. It sounds as though you may need a new battery. Have you checked the charger itself to make sure it is working properly?
Jun 10, 2009 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
