Question about Bunn VPR Coffee Maker
Adjusting temperature for bunn cwtf twin
How to increase the temperature on bunn coffee machine...i already removed the front plate and adjusted to hi...is there any other way...if yes plz let me know the steps...i dont know to know how to get to the tank
thanks
    President:
  • 1,618 Answers
Look for the black knob with the arrow and it might have a red paper tag attached, turn clockwise all the way, then back about 1/4 of an inch.
Posted on Jun 18, 2009
Bunn cwtf adjust temperature
u must locate the lock bottom to open and re- programs ur temp. settings...
Jun 27, 2014 | Bunn CWTF 15-APS Coffee Maker
I have a bunn cwtf twin,I put new ready lights on both side work for about a week and the they wont light up. and the side the the faucet only brews warm coffee. but the other side does find. HELP
The green ready lights do not last that long. We never replace them on units we service. They are cheaply made. Each side of this coffee maker has its own thermostat. Check to make sure the thermostat is on all the way. If it is check the voltage on the warm side. Make sure it is in the 208v area. This warm problem is 85% the thermostat not set right and or needs replacing.
Apr 28, 2014 | Bunn CWTF Twin TC Coffee Maker
What size breaker do I need to install a CWTF - Twin 4/2? I have 208 volts available. Wattage is 6850.
A 50 amp breaker would be best. To find proper amperage its Watts divided by volts, then multiplied by 1.25 for draw.
Jul 16, 2010 | Bunn CWTF Twin-TC (23400.0047) 12-Cup...
My bunn cwtf 15 wont put out hot water and the ready light wont turn off dustain
If your ready light is on and your water is not warm... sounds like the thermostat is too low. Inside the front panel (behind the brew basket) there is a thermostat adjustment on the left-hand side. If you turn that up your ready light should shut off. You can then adjust the temp to your desired level. (194-200 degrees depending on roast, grind, etc...)
Jun 14, 2010 | Bunn CWTF15-TC
Installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
Which grommet, there are several on the bunn models, but the most commonly replaced one is the one for the P. stat. Remove the top panel there are 2 screws one in front and one in back, then lift the top 2 burners off machine that will give you access to the tank.
Apr 30, 2010 | Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
Our Bunn CW series three burner is over filling. How to correct the problem??
needs service tech to adjust.
(Do it yourselfers can adjust the black knob down from 2.5 to about 2 mins. Digital timers have instructions in back of the front panel. CAUTION!! There is high voltage present. Pull out the plug! Safer to just have it serviced.)
Feb 03, 2010 | Bunn CWTF 15-3 Coffee Maker
Bunn cwtf15 coffee isn't hot enough the coffee brews @115 degrees
Adjust the thermostat, located behind the front panel, there will be a knob, turn all the way on then back about 1/4 turn.
Dec 07, 2009 | Bunn CWTF 15-TS Coffee Maker
Adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Jun 17, 2009 | Bunn VPR Coffee Maker
Bunn VPR Coffee Maker Logo
446 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
Marvin
Marvin
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
