Need to set new code but don't know the PC
look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
SOURCE: I need to replace the deadbolt. What item works?
Your best bet is to contact Kwikset directly. Here is a link to the contact information that you need:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
SOURCE: i have a kwikset deadbolt
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
SOURCE: how do you change code on Kwikset 907 keyless
For troubleshooting:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above may be a .PDF file type. That means that you need
to have Adobe Reader or similar installed on your computer to view it.
So if you are unable to view the file, download (for free) and install
Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
SOURCE: brought new keyless dead bolt. Put it in a door
My lock adjusted itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
