Question about Panasonic KX-FLB756 Plain Paper Laser Fax
Error code 3
  • mchapa Nov 01, 2007
Change drum
Posted on Jul 09, 2008
    Problem Solver:
  • 10 Answers
Do you service 3????
check the fuser unit.. check the fuser roller,see if it it deteriorated.. check the fuser thermistor.. check the physical apperance,, see if the plastic seal is already tampered.. just give focus on fuser unit
Posted on Jan 30, 2008
Wanna download the software
Posted on Jul 22, 2008
Panasonic fax machine 402 having error call service 3 please tell me the code
Press Menu first, then #9000*, next press 550, press Start, wait for printing, unplug the electric cord, wait 10 seconds or more, plug it again - sorted.
Dec 26, 2017 | Panasonic Office Equipment & Supplies
Error code is call service 3 on the Panasonic fax kx-fl422
You need to contact Panasonic Service personnel to resolve any error code that begins with "call service." Please call or e-mail using the following contact information:
Obtain Product Information and Operating Assistance; locate your nearest Retailer/Dealer or Service Center; purchase Parts and Accessories; or make Customer Service and Literature requests at:
E-mail Panasonic tech support via:
For in Limited Warranty programming and Troubleshooting Support:
Office Advantage assistance and Service Location finder: 1-800-211-PANA (7262)
If the Limited Warranty has expired, contact Continued Services Technical Support Line at 1-800-435-7329, for fee based technical support. A credit card will be used to charge this fee.
Mar 07, 2011 | Panasonic Office Equipment & Supplies
Call service 3 panasonic kx-fl612
hello sir i have panasonic fax kx-fl 612 error code is call service 3 pls help us how i can run my fax plz
Jun 24, 2010 | Panasonic KX-FL611 Plain Paper Laser Fax
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
enter the service mode
Apr 02, 2010 | Panasonic Workio DP-2000P Copier
Where's the fuser unit on a Panasonic DP 3000
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
May 16, 2009 | Panasonic Workio DP-3530 Copier
E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Jun 19, 2008 | Panasonic Workio DP-3520 Copier
Error code 3
Turn ON the machine then press MENU then #9000* then press 550 then press START and last thing turn OFF your machine or unplugged it.
Nov 08, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Error code RC3
I absolutely can't believe this worked for me, I'm so excited!! My error was RC3; my remote had an OK button (not Enter) for a Panasonic DVD/VHS recorder. I held down OK and the number 3 and the remote started working!! Thank you so much, I was getting very frustrated!
Sep 12, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic KX-FLB756 Plain Paper Laser Fax Logo
428 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
