Question about Epson Stylus CX9400 Photo Printer
Changed all four ink cartridges and now every photo I print has a yellow color to it. I have done all of the maintenance twice and reseated the cartridges...no luck. Any ideas?
  • 523 Answers
Check the Nozel of the yellow one , it looks bad coz it keeps putting color for every copy.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Jun 17, 2009
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
Color on photos suddenly has a blue - purple wash with no greens
Your yellow cartridge is probably not working as your photos suggest. Remove and reinsert the yellow cartridge. Try printing only yellow color.
Your printer has a separate head for printing; the nozzle for yellow ink might be clogged. Try running a head cleaning routine from your printer software.
Sep 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Not printing - just replaced ink cartridges
Reseat the cartridges.
Do 3 consecutive head cleanings.
May 02, 2009 | Epson Stylus C84 InkJet Printer
No shadow density in photograph printing
If you haven't been printing for 6 weeks, your print head is clogged, which is why the print quality is poor. Turn your printer on. On your computer, go to START, then SETTINGS, find PRINTERS AND FAXES and click on that. A window will open and you should see your printer. Right click on it, then click on PROPERTIES. A window will open, with several tabs. The one you need is MAINTENANCE. Open the tab and click on CLEAN PRINT HEAD. I think there are 2 options, cleaning and deep cleaning. Click on deep cleaning. You should hear the printer rumbling, then, when it finishes, it should print a page with 4 colors: black, cyan, magenta and yellow. If the colors come out right, you're done. If not, repeat the cleaning until you get a satisfying result. Just bear in mind that cleaning the print head uses a lot of your ink, so I suggest you put the refilled cartridges when performing this operation.
Also, to avoid getting in this situation again, I suggest that you print one page, at least once in 10 days. That way, your print head should always work fine.
If you found my answer helpful, please vote, it really means a lot to me to know weather I am helping someone or not.
Jan 13, 2009 | Epson Stylus Photo® RX620 InkJet Printer
Wrong colors when printing on photo paper
yha way not
if you worry about wrong colors
it is possible you 3 colors cartage has mis a color it is maybe red,green,are yellow, refill your cartage and print again
Dec 16, 2008 | Canon Pixma MP500 All-In-One InkJet...
IP4000 Color prints look washed out/yellow
Check the custom settings in the printer properties. Try playing around with different settings till you find the one that suits you best..
May 11, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Lexmark x5150 color printing issues
Sometimes ,poor print quality may be due to ink build up in the maintenance station ..
Your ink cartridges stay in the maintenance station when not in use. Depending on the printer model, the maintenance station may be located on the right or left side of the printer. NOTE: You do not need to remove the cover in order to access the maintenance station.
To access the wiper for cleaning purposes:
Unplug the power cord from the back of the printer.
Move the ink cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right-hand side of the printer.
Take a warm, damp paper towel or napkin and gently clean the wiper on the right-hand side of the maintenance station.
Mar 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
Excessive Yellow ink use
Issue The printer is working, but the colors in the printed output are not the expected colors. The output may look as if only one color has printed, or as if a color has not printed, or as if the wrong colors have been printed. Solution Complete the following steps to resolve this issue. Step one: Check ink levels If the print defect is minor, it might be caused by reserve mode operation. When the printer runs out of some colors, it can continue printing using remaining inks, but print quality may be affected. If cyan, magenta, or yellow is out, the printer can print only in grayscale.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. If ink cartridges have been refilled, try replacing them with genuine HP ink cartridges. Replace any empty print cartridges. To access the ink level gauge, follow these steps.
  1. Press Setup .
  2. Press c00707172.gif to select Tools , then press OK .
  3. Select Display Ink Gauge and press OK . The ink levels are displayed. Figure 1: Ink levels c00410056.gif
    • Each icon corresponds to the cartridge that is the color of the icon. The icons are also in the same order, from left to right, as the cartridges in the printer.
    • If an icon is empty, the corresponding cartridge may need to be replaced soon.
    • The ink levels in non-HP, refilled, and remanufactured cartridges cannot be read by the printer. Instead of an icon, a question mark is displayed for these cartridges. HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty.
Step two: Calibrate the color If the cartridges have not been refilled and none are empty, try calibrating the color.
  1. Open the printer Toolbox :
    1. Open HP Solution Center (click Start , then All Programs , then HP , then HP Solution Center ).
    2. If you have more than one printer installed, make sure to select the correct printer tab in HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
  2. On the Device Services tab, click Calibrate Color , then follow the onscreen instructions. The procedure takes about two minutes and requires two sheets of paper.
Step three: Clean the printhead If the steps above did not help, clean the printhead.
  1. Open the All-in-One Toolbox :
    1. Open HP Solution Center (click Start , click All Programs , click HP , and then click HP Solution Center ).
    2. If you have more than one All-in-One installed, make sure to select the correct All-in-One tab in HP Solution Center .
    3. Click Settings .
  2. On the Device Services tab, click Clean the Print Cartridges , and then follow the onscreen instructions. Three levels of cleaning are available.
Step four: Contact HP If the error still occurs, click the link at the bottom of this page to contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00707165&lc=en&cc=us&dlc=en&product=1153481&rule=45772
Jan 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Epson Stylus CX9400 Photo Printer Logo
50 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
