Question about Xerox Office Equipment & Supplies
Need part #'s for pick and feed rollers for all trays on a Xerox Copier 5837
    President:
  • 2,072 Answers
Google a business called "the parts drop". Look it up there or call Britt.
I do not work there. Just do business with them. Top notch service and fair prices.
Posted on Jun 18, 2009
Paper won't feed from the tray, the display shows P. Opening and closing the tray restores the machine. A single sheet of paper will feed from the bypass.
The pick up roller need to either need to be clean or replace. Because of the price to replace the pickup roller it might be worth more to just get another printer.
Oct 19, 2013 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox 416 Work Centre Pro Paper Jam
You should first have a check over the roller . Mostly the problem will be the roller only .
But let me know how old is your copier ?
Depending on it we can solve your problem .
SAM ANDERSON
Sep 23, 2008 | Office Equipment & Supplies
Paper feed tray
HP had this problem. There's a small roller inside and a pet snaps off so it can't put enough pressure onto paper to pull into machine. Check for broken parts. And check for any grease that might have contaminated roller.
Jun 21, 2013 | Xerox CopyCentre C20 Black and White...
I picked up a 5830 copier and a paper jam is in the LCD I followed the instruction, and there is no paper caught into the area per the displayed area or in the paper path period. Code is D3-1 Do you have a...
The machine has been sitting around for a while, or was just been stopped being used.
Try cleaning the brown roller in Tray 2.
Try the other paper trays see if they work. Tray 1 and tray 3.
We would need more information about the results of these areas and how it worked.
If there is alcohole, try cleaning the brown roller. The other rollers are harder to see. This machine could even have bad paper feed clutches.
A xerox serivce call would have to be placed to do the major repairs.
Oct 03, 2009 | Xerox 5830 Copier
Please help re: Xerox 2515 large format copier
the first step is to pull the paper out and see if the feed rollers have left a mark on the paper that would mean your rollers are turning just not picking up the paper if this is the case remove the paper tray and with a wet rag clean the feed rollers always easier with a flash light keep in mind they may need to be replaced call 7734748865 il b happy to help
Jun 26, 2009 | Ricoh Aficio 450 Copier
Can I disable the lower print tray?
Hi wogan2:
Normaly when you get this problem it means that you need to replace the feed rollers in that tray.
Inspection
Rollers:
Replace the rollers when you see any of the following defects:
 Flat spots
 Out of roundness
 Cracked rubber
 Loss of traction (tackiness) causing pick or feed failures.
Xerox paper pick roller
Part # 401-0882-00
Hope this helps
May 21, 2009 | Xerox Phaser 8200 Laser Printer
PC795 Won't feed from originals tray
Hello sir; There have no paper jam because the paper pick up roller not kickout the paper, replace the paper pick up roller.
Mar 30, 2009 | Canon PC-795 Copier
Xerox 5837 with 08-310 Error
If you donot find paper in the machine check for a stuck actuator or a bad sensor.
Jun 03, 2008 | Xerox 5830 Copier
55 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
