Cars & Trucks Logo
Posted on Jun 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1992 Lexus SC300 Air Condtioner blowing cool/warm
My 1992 Lexus SC 300's AC blows cool air (NOT cold) and then gradually gets warm, then up to whatever the outside air temp is.
what is most likely wrong?
  • 1 more comment
  • dthoeting Jun 17, 2009
    It does this when on recirculation and/or fresh air
    All guages seem to be working - the display says "cold", "75" etc, but the air is warm
    thanks so much for responding
    This would be the old freon --- hope it's not expensive
  • Michael Grey
    Michael Grey May 11, 2010
    Is the setting on recirculation?
Marvin
Level 3:
Top Expert:
  • Lexus Master 85,242 Answers
  • Posted on Jun 17, 2009
Marvin
Lexus Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29055498
Points
266281
The system is low on charge, it has a leak, repair the leak and recharge
  • Marvin
    Marvin Jun 17, 2009
    the 1st thing to do is have the system charge level tested, then if that checks ok u may have a temperature control blend door problem.
2answers
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
My 1996 Lexus ES300 ac blows cold for a while then starts blowing warm air. Then I turn it off for a while
There are a number of possibilities.
1. If the compressor has a clutch, do you hear it engaging and disengaging?
2. The valve controlling the hot water going to the heater which mixes warm air with the cold air from the evaporator, is not working properly so it si not maintaining proper temperature.
3. THe temperature sensor that senses air temp at the intake to the AC in the cabin is defective.
4. THis is too comlicated to fix yourself, so you need to take it to an AC expert who knows this particular model.
I have 2000 ES300
My girlfriends 2003 beetle,s ac does not blow cold air. This happened after an issue with low coolant. Is there any connection here, or is there other potential causes?
does it blow cold ac when the car is started after sittin overnight? if it does and gradually gets warmer as the car warms up, then you may have an air bubble in your cooling system caused by the low coolant level. if it blows warm anytime, then your ac system may need to be inspected or recharged.
Why does the heat on the drivers side only blow cool air and all other vents blow warm
chances are you have climate control. check and make sure your driveside control is on warm air and not cold air.
1998 gmc sonoma air conditioner - not cold
Check the magnetic clutch is engaged on front of a/c pump, have the motor running, a/c on and fan on high, if the centre hub is static the pump in not switched on, this can happen when the gas pressure gets low.
2answers
1993 lexus sc300 missing
Check the temperature sensor, next to the temperature gauge sensor, did check engine light comes on?
1992 es 300 lexus heater is blowing cold
. Yes it could. some are vacuum powered, cable powered (mechanically) or electric powered. If the valve does not open. The hot water will not get to the heater core. It could also be the thermostat not opening.
Heater blows cold air
With the car warmed up,feel the heater hoses,are they both warm/hot near the firewall in the engine compartment?If they are both warm/hot,then the heater core should have circulation through it and it may be a "blend door" issue in the heater a/c assembly.If they are not warm/hot then the heater core could be dirty and plugged up and needs to be flushed.
If the above does not help,a drain and vacuum of the cooling system and vacuum refill will remove any trapped air.
Sometimes,clamping off the top rad hose and holding the engine rpm at 2000 rpm will force trapped air out of the heater core.(Watch temp gauge when trying this)
Lastly,a NEW thermostat doesn't mean its working correctly.
Will not start when warm
check the coolant temp sensor for the computer side.will cause simular problems.
1helpful
1992 sc300 lexus
it is under the vehicle, driver side, below the seating area, in front of the rear wheelwell, mounted on chassis in fuel line.
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Lexus Expert? Answer questions, earn points and help others
