Hi
Did you check the fuses for the turn lights? Do the
parking lights work? If the parking lights work then you probably have a
problem either in the switch or in turn signal module thing.
The burned out bulb is what might be causing it not to blink... if one bulb is burned out you gotta replace it, make no difference if front or back,the left blinker will not work if the left front or rear bulb is bad.
same with the right side. if the front right or rear right turn signal
light is burned out it will not work.....get replacing the bulbs.Hope this solves your problem.Please rate me if my solution helped you.
Regards,
bonefirediv.
