Question about Candy DFI Plan Built-In Dishwasher
My dishwasher wont wash - Candy DFI Plan Built-In Dishwasher
  • 6,784 Answers
I recommend inspecting the following areas.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer/Control
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Jun 18, 2009
Why wont my frigidaire dishwasher wash?
There could be something blocking the drain. There are parts on the base inside the dishwasher that can be removed and then cleaned.
Nov 08, 2014 | Dishwashers
Why my dishwasher wont start?
Sounds like you have a bad control console.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 27, 2014 | Kenmore Dishwasher With Ultra Wash And...
Elxtrolux front load wash/dry machine motor wont spin
Yes it is the timer Also check the lock button under the lid for obstruction or damage from opening the lid too soon the time before you did a wash .
May 14, 2012 | Electrolux EWDW6505GS Fully Integrated...
Dishwasher wont wash! just makes a humming noise
Without knowing the brand and model it makes it a little hard to anser but I can tell you thats the typical sign that there is something wrong with in some machines, the pump/motor assemble, in others the recirulating pump, but a technician should be called.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 29, 2012 | Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My miele wont wash it starts up then stops an wont drain out then the water intake light comes on
Hi If appliance fills then starts to wash then stops and starts. Then most likely cause is debris in circulation motor. This will require appliance and motor to be removed
May 21, 2010 | Miele 24 in. G643Vi Plus Built-In...
Washing machine wont spin
If your washing machine wont spin it and wont empty the water it is a blocked drain pump. You may have a faulty lid switch or it could be going out of balance.
Feb 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I put washing up liquid in mu cda dishwasher now it wont do anything it wont rinse
If the machine cavity is full of suds, use a 'wet-or-dry' vacuum to remove all of the suds possible, then run a washing cycle without dishes or detergent to flush the machine. With luck, the machine will be back to normal.
Feb 08, 2010 | Electrolux 23 in. ESL624 Built-in...
Dishwasher conrol panel light comes on but it wont go into wash cycle
All dishwashers usually start by draining first, if your machine does not detect that your machine is empty it will not start to wash. There are a few resons why this can happen, could be the pressure switch is stuck. Some machines ie bosch have a float switch mounted in the base so if your machine has leaked underneath and lifted the switch it will just stay on drain.... would help to know the make and model number
Jun 14, 2008 | Dishwashers
Candy DFI Plan Built-In Dishwasher Logo
645 people viewed this question
Top Candy Dishwashers Experts
 Evgeniy_Getz
Evgeniy_Getz
Charles T Nevin
Charles T Nevin
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
