Question about Golden Technologies Companion II Travel Scooter
Companion II. The light blinks 7 times over and
Companion II. The light blinks 7 times over and over. The little light on the dash just above the key. Scooter will not go or move. What do i do? onecornflake@gmail.com jim 559-292-5528
    Problem Solver:
  • 13 Answers
7 light error refers to paddle or speed
potentiometer problem, if you feel confident taking the covers off then check that all the connections are nice and firm, also on other scooters if the paddle is not located in the neutral position when you turn the scooter on the control box will detect this and "lock out" the scooter, you can fix this using trial and error but it can be very fiddly! (yes iv had to do this before!) if all the connections seem quite solid and on the control box this would possibly suggest that either the potentiometer has failed and will need replacing (which would mean reconfiguring the paddle when its in) or there is a fault in the control box, if you dont feel comftable/cant fix this problem then obviously i would reccomend taking it to an authorised repair shop, i hope this helps you if i can be of any furthur assistance then my email is rick @ lxrixta.co.uk (remove the spaces!)
Posted on Jun 18, 2009
Bose Companion 2 speakers and Windows 7
Scan your computer with RadarSync so that it will detect which driver updates are needed. It will grab the drivers and update them.
David
Jun 26, 2013 | Bose Companion 2 Series II Multimedia...
I have a Golden GC321 When the battery charger is on there is a green light and next to it is a red light Does the red light ever go off when charging.
the gc 321 has a diagonistic sender built in, go to golden companion.com
and down load the owners manuel for it, its free and very helpful, when you 1st turn on the key , you count the times the red lite blinks an it will diagnose your problem, then you look it up in the manuel!
also go to monster.com and type in make and model, a set of keys is about $10
Mar 04, 2013 | Golden Technologies Golden CompanioN II -...
Golden companion II full charge turn key on press lever to go forward it dont move hear clicking sound green light on dash blinks
John count the number of flashes by the green light and it will be the fault code indicating the problem Your owners manual should list the fault codes to be able to determine what the problem is. Ie 4 blinks pause 4 blinks pause. The clicking you hear is the electric brakes being engaged. Hope this helps
Mar 01, 2011 | Golden Technologies Companion II Travel...
HOW CAN i GET MORE THAN 3 HRS DRIVE TIME ON MY COMPANION 11 SCOOTER?
I'm not to shure the dimensions of your two batteries but this is what i would do. (i go to high school so i have a bunch of time on my hands) Try some car audio batteries like these. http://www.sonicelectronix.com/item_17907_SHURiKEN+SK-BT20.html
http://www.sonicelectronix.com/item_17902_SHURiKEN+SK-BT35.html
you are probably going to have to copy and past the links. if these can rune a car stereo all day then they should run your scooter for way more than 3 hours.
Sep 10, 2010 | Golden Technologies Golden CompanioN II -...
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
I haVe two golden companion scooters that worked Perfectly. One day they just quit running. I know that when the light blinks a certain number of times in the manual it tells you what's wrong. Both of mine...
Hi. 5 flashes on some scooters is the fault code for brake coil open circuit. This usually means that the free-wheel lever is in the wrong position.
Someone might have moved the levers so that they could push the scooters, and forgot to put the levers back to the correct position.
This fault code can also mean that the solenoid coil is faulty, but 9 times out of 10, it is the lever in the wrong position.
Good luck. Neil.
Jun 12, 2010 | Golden Technologies Golden CompanioN II -...
Not moving and green light is flashing
this is batteries
if slowed down first then stopped
mobility centre penge
Apr 14, 2010 | Golden Technologies Companion II Travel...
Golden Tech Companion II: Doesn't go, batteries
Accessibility Specialists Inc
1815 Corporate Sq Blvd
Ste 200
Jacksonville, FL 32216
(904) 725-0601
Nov 21, 2009 | Golden Technologies Companion II Travel...
Scooter will not move
make sure you have put it back in gear, sometimes the freewheel lever is not fully engaged. the light should not blink when the lever is in the drive position.
Sep 11, 2009 | Golden Technologies Companion II
How to dissasemble golden companion II
Companion-2 scooters. Remove seat by holding up on seat lever and picking up seat at the same time. Then remove bolt from seat post and remove seat post. Remove rear cover. Unplug and remove batteries.
Jun 29, 2009 | Golden Technologies Companion II Travel...
Golden Technologies Companion II Travel Scooter Logo
302 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
