Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
No video output from motherboard
I used canned air to clean the mother board and now the computer has no video output.. the monitor works fine.. tested on another computer
  • Luis Aguirre
    Luis Aguirre Jun 17, 2009
    everytihng looks connected..i did not wear any wriststrap... i took computer outside and set it on car ( not recently driven ) and air canned it..all fans are working just fine..the moment i connect the monitor, it goes to sleep... it is a MSI motherboard and using the onboard connection for monitor.. i have tried to almost every thing that I can think of............
    Problem Solver:
  • 7 Answers
Make sure that everything is still plugged in good on the motherboard, like the video card. Could be you just knocked something loose. Also, did you wear a wrist strap to prevent static or at least ground yourself out? If not, you could have shorted out the board. Also, do you hear all of the fans running on the computer? Another thing, sometimes canned air is kind of damp for just a few seconds. I am assuming that you unplugged your computer before you used the canned air on it?
Posted on Jun 17, 2009
  • JGTremillo Jun 18, 2009
    If you are sure that everything is plugged in good, all of your cables inside the computer and the monitor cable...are you not hearing any kind of beep codes when you boot it? I hate to say this, but it sounds like the motherboard went out. Now when I say "motherboard," there is a possibility that it is "only" the processor on the motherboard. It is simpler and often just as cheap to replace the whole motherboard and processor rather than trying to replace only the processor and finding out later that the motherboard also has a problem. If you aren't comfortable with doing that yourself, it might be a good time to take it in to a technician. Most places will charge you an arm and a leg to fix that problem. A good technician should be able to back up your data from your hard drive. It doesn't sound like anything is wrong with your hard drive.
Hello, i am using 845gvsr mother board , its working fine but there is no dislay
first remove the cable from the monitor and see whether the monitor is working fine then fix the monitor firmly on the display socket in the computer remove the computer cover then remove the memory card from the slot and clean it with a clean cloth then remove the dust in the slot using a brush then switch on the computer with out the memory if you hear a 3 beeps then switch off the computer and insert the memory if you dont hear the beeps then remove the processor clean it and apply a paste of heat sink compund and fix the processor fan firmly to the socket
May 01, 2011 | Intel D845GVSR Motherboard
The computer was in use when the display cut out. The monitor is fine and the computer turns on but has no display on the monitor
I presume that you tried the monitor on another system to verify function. Try restart after 2 min power down and disconnect and try again, then take another "known good" monitor and try that. If both monitors give no image, video output is suspect. Many motherboards have the video output as part of the board itself, cost prohibitive to replace motherboard.
Sometimes you can plug in a PCI video card and bypass system video.
Oct 01, 2010 | Gateway GT5622 PC Desktop
No Display on Mother Board
Have you try troubleshoot with working monitor, display card or your matherboard and processor,
Usually no display problem occur becouse of one hardware between monitor, ram, motherboard, displaycard and can be your processor problems.
You can try troubleshooting one by one of your computer hardware to get problem occur
Jul 21, 2010 | Intel Desktop Board D845WN Motherboard
My computer has no displayed on the monitor but has a power,it's attached to the built-in video card of mother board the model of my mother board is "K7MOS+7.5C" what should i do???...
Hello Wongcarlkley, hi, looks like you have memory module problem, need to clean module contacts using pencil eraser, try this fix first and see if it will solve your problem.
May 05, 2010 | EliteGroup K7SOM Motherboard
Adding a video card and get no output
Look in the motherboards manual for info about installing graphics cards, see if it needs jumpers. Plus make sure you plugged the monitors vga or dvi on the right place (VGA or DVI port ON the graphics card, NOT on the old vga port you used to plug your monitor before )
See if it works otherwise tell me..
Sep 14, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I have asus p5p800-mx mother board morboard working fine and also start but on monitor no display and i also try to install additional graphics card then also no display
Have you tested the monitor to see if it is working? Is the vga cable good? Are you getting the BIOS start-up display screens when computer is booting up or no display at all? It is odd that both the on board video and video card would be bad I would double check the cable connection and the monitor. If the cable is good and the monitor is working properly than the board might be bad. You should at least get the BIOS start-up screen display.
Sep 07, 2009 | ASUS P5P800-MX Motherboard
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No output to monitor
try another video card and/or monitor
Oct 19, 2007 | EliteGroup GeForce 6100SM-M Motherboard
Mother board
It's a possible motherboard issue. Had same issue and troubleshot to the MB. Everything else checked out fine. PC was working fine up till then.
Sep 13, 2007 | HP Pavilion a1240n (EG136AA) PC Desktop
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
211 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
