Question about Frigidaire ATF6000ES Front Load Washer
E70 I have a frigidaire gallery series that I just bought from someone. No instruction booklet came with it. I always get an error code E70. What is this & how can it be fixed? Thanks!
  • 6,784 Answers
HI, this is a major control board fault code. the chip set on this board is damaged. it cannot be repair and, it is recommended to replace the entire control board(main) in this case.
A service call is recommended.
Posted on Jun 17, 2009
Directions how to use self cleaning over on the fridge re gallery gas stove
Hello, Joan -
Clarification: You are asking about a Frigidaire Gallery model gas stove and how to use the self-cleaning feature for the oven? If so . . .
You will find the instructions here:
https://www.hunker.com/12002208/instructions-for-a-frigidaire-gallery-series-self-cleaning-oven
If you need the user manual for your oven, you can add the model number by choosing Comment and adding the information there, so I or someone else volunteering to answer on Fixya.com can look for and provide the right link for a download of a free manual.
Note: There is more than one Frigidaire Gallery range model numbers made:
https://www.frigidaire.com/Kitchen-Appliances/Ranges/View-All/?filter=Feature02012:Feature02012
Best wishes.
Apr 06, 2018 | Kitchen Ranges
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
Dryer gallery series e68
Good Morning Friend,
I understand you want to know how to replace the board on your Frigidaire dryer, model# GLEQ2152ES, due to receiving an E68 code. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to replace the board with ease. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Dryers
Frigidaire washer LTF7000ESO error code E70
Good Morning Jazy, this is JK. I see that you are receiving an error message E70. The E70 error means that the Main Control Board is not seeing the correct water supply. I would suggest swapping the hot and cold hoses. Hope this helps!
Mar 24, 2014 | Frigidaire Washing Machines
Error codes for a frigidaire gallery series model gleq2152es0
Check out this affinity manual for error codes on electrolux dryers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2012 | Frigidaire Dryers
I bought a used gallery, ran a clothes free cycle first with bleach, then washed a load of clothes. No sound at all during first run, very noisy when clothes are in, rubbing sound, like a bearing? Third...
The seller may have unloaded a defective appliance on you! Recoup your money. Purchase elsewhere. Sounds like the appliance has at least two different issues.
Feb 20, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Attach washer to pedestal
there should be bolts that come with pedestal so you need to take your legs out of the washer now lay it on its back then bolt the pedestal up to it and if the pedestal dont have feet put the ones out of the washer on it
Dec 31, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Error messages
what are other codes? i believe this could be a cold water issue. check your screens at the fill hoses
Sep 22, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire ATF6000ES Front Load Washer Logo
299 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
