Question about Honda Water Pump Honda Engine
I NEED TO BUY A 5 HP, 2" TRASH PUMP TO FILL A 1600 GALLON TANK.
THE TANK IS 5' HIGH AND I WANT TO TO FILL IT THROUGH THE BOTTOM OF THE TANK. I NEED TO KNOW IF A PUMP WITH THESE SPECIFICATIONS WILL HAVE ENOUGH POWER TO FILL FROM THE BOTTOM AND PUSH THE WATER UP. I HAVE A 10' LIFT FROM MY WATER SUPPLY TO MY PUMP AND MY PUMP IS LEVEL WITH THE BOTTOM OF THE TANK
3 Suggested Answers
  • 57 Answers
SOURCE: 2" honda trash pump haw no presure
Maybe you trashed it. Take the cover off and look for any debris in the impeller. Also make sure you don't have any air leaks on the intake side of the pump. If the pump is ok and the engine bogs under load then the high speed jet could be out of adjustment or junk i the carb. Remember don't run the pump dry. You can also try adjusting the jet while it is running. Remember turn the needle slowly until it runs better.
Posted on Sep 12, 2009
  • 881 Answers
SOURCE: I can't fill my tank up with gas on my 2004 Honda
Your problem is the breather on the tank
Its a pipe fitted to the tank that lets the air out when you put fuel in. and it sounds like its blocked up or has a kink in it
Find it ,clean it, and your ok to fill up.
Posted on Sep 30, 2009
How to empty gas tank on honda odyssey
remove fuel filter install rubber holes to gas can cycle key to pump it should gravity feed from there. be sure to put some gas in glass jar to look for water or trash.
Feb 04, 2018 | Honda Cars & Trucks
How many gallon gas do the gas tank hold?
Fill it with the gas can and then go to a gas station. Your gas can can't be much bigger than 5 gallons, there's very few that are larger because they get heavy. Your gas tank is vastly more than 5 gallons, probably 15 or more in an Envoy.
Nov 20, 2016 | 2004 GMC Envoy
Will not prime
must have water in it to prime ,fill up the tank with about 4 gallons of water or may have the impeller is broke or it could be plugged with trash make sure you pump basket has no cracks , see picture on how 2 remove your pump .find your local pool pump motor repair guy and ask him how 2 take better care of your pump.. he can save you thousands of dollhair$ over the years .. jay pump guy longwood Florida9_30_2011_8_01_56_pm.gif
Jun 21, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Fuel comes back out fill tube when fueling 04titan king cab
With the information you've provided, one cam only imagine that you are obviously over filling the tank.
So this leads me to suspect that maybe (just maybe) your gas gauge is saying you are on empty, or 1/4 tank or a 1/2 tank whatever, etc. And you are wanting to make sure it is full.
I presume it always says this and that perhaps you need to have the sending unit replaced inside your fuel tank.
Otherwise, if all things are in working order and you meant to say that the Pump Nozle that the service station uses (where you fuel up) is not shutting off when your tank is full.
One of two things are happening,
In the case of a pump handle that has an auto lever, either they have a faulty pump nozle, in which case you need to talk with them about this.
OR
It is a manual Nozle, in which case you are holding the lever personally and are over filling your tank...
It would be advisable to look up the total fuel capacity of your tank and make a note of approximately how many gallon are in it before fueling up.
This way, if you know there are say around 5 gallons and you have an 15 gallon tank.
Adding even 10 gallons you would be running the risk of over flowing since you are only estimating say 5 gallons at the beginning, maybe it is 5 1/2 or even closer to 6. Therefore only about 9 gallons could be added without over flowing...
Hopefully you'll have found something useful in this.
Good Luck and happy motoring
Respectfully
Jun 10, 2011 | 2004 Nissan Titan
How much oil does a ts-7 ingersoll rand compressor hold
Approximately 2 liters. Fill to the bottom of the fill plug threads.
Mar 15, 2011 | Ingersoll Rand Compressors 5-HP,...
Air compressor runs but i only get 20 psi i check for oil but i never find were to test the oil level do this air compressor is oilless?
Yes it has no oil. and you need to remove the top cover and check for air leak between the pump an the tank. if you have a large leak the tank will not fill. Two screws and the cover should snap off. check copper line for blown seals.
Feb 08, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Full Tank very fast
witch model do you have, for some models thats normal on others its not, some run the water over hot coils and it evaporates others the water goes into a holding tank and sits their til the tank fills up then you must empty. expect more water when high humidity or in the summer
Jun 27, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Open Questions:
See all Honda Water Pump Honda Engine Questions
Honda Water Pump  Honda Engine Logo
76 people viewed this question
Top Honda Tools & Hardware - Others Experts
gbob59
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Honda Tool and Hardware - Other Expert? Answer questions, earn points and help others
