Question about 2wire HomePortal 1000 Router
CAN I CONNECT MY 2WIRE MODEM TO MY CABLE MODEM AND MAKE IT HARDWIRED SO THAT I CAN ACCESS MY LAPTOP WIRELESSLY?
  • 244 Answers
For exact instructions on how to do just that, follow this link
http://support.digidave.co.uk/index.php?_a=knowledgebase&_j=questiondetails&_i=176
Please don;t forget to rate this answer if its helpful
Posted on Jun 17, 2009
2wire 1701 hg dsl connection drops when laptop is connected via wireless
This is a known issue with this model.. The power supply is not large enough to handle the extra current that is needed when the unit broadcasts on wifi.
May 05, 2017 | 2wire Computers & Internet
I have my computers and laptop networked through my 2wire Home Portal 1000SW modem and am trying to connect my Coby Kyros MID8024 Tablet through wifi. The tablet finds my 2wire network but seems not to...
1st make sure that your using the proper WEP key (Wireless Password) 2nd make sure that their wirelessly compatible SW is a wireless b compatible to eliminate this issue you may also disable your WEP
majority of new technology uses wireless G and N
this wireless modem is a little bit outdated:
Data Link ProtocolEthernet , IEEE 802.11b , HomePNA 2.0 , HomePNA 1.0 , USB
see for your tablets protocol if this would match:
Aug 28, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Cannot connect my dell laptop wirelessly, will connect with a wire and will connect wirelessly at the library. The old 2wire was ok but we replaced it with a new 2wire today. Have spent 3 hours with att...
Since you are able to connect using a hardwired connection and you're able to connect wirelessly at the library, that simply means that your computer and your internet browser are fine. where is your wireless computer and your wireless located? are there any possible wireless devices interfering with the wireless signal like chordless phones, cellphone, TVs, radios, microwave oven? are your walls in your house covered with metal plates coz that would really make the signal deteriorate. the settinngs on your wireless router may also need to be reconfigured and boost up the signal of the wireless router.if only i could remotely access your wireless router, I would really walk you thru on what to check on your wireless router
Jul 07, 2011 | 2wire (1000-000057-000) Modem
Can I connect a second computer (not a laptop) in my bedroom wirelessly to the 2wire modem that I have connected to my main PC?
Yes, you can. just make sure that the computer has a wireless capability, if not then you need to connect a wireless adapter so you could connect the computer to your 2wire router wirelessly. Another possible way to have it hooked up to your 2wire router is via Ethernet cable but depending on the distance you may need a longer cable.
Oct 10, 2010 | 2wire (1000-000057-000) Modem
Cable and wireless question
Not possible, since the "input" to the 2WIRE modem is a 4-wire telephone-line, not an 8-wire Ethernet cable.
Instead, spend about $40 to buy a D-Link Wireless G modem, and connect its WAN port to the cable-modem, and connect up to 4 Ethernet cables to "wired" computers, and configure the "wireless" component of the D-Link router.
May 07, 2010 | Computers & Internet
Xbox 360 wireless adapter wont connect to my 2wire
Have you tried removing all security protocols on the 2wire and trying to connect?
Good Luck!
Jesse
Jan 05, 2010 | 2wire HomePortal 1800HG Router...
How do i connect a Linksys wrt54g2 to a arris cm450a
Your modem is capable of linking up to a router. What you do is take an ethernet cable and run it form the internet port on your modem to the internet/wan port on your router. From there you connect your pc's into the LAN ports on the router (typically labeled 1-5) if they are hardwired or you connect wirelessly with your laptop. You need to also power cycle/reset your modem when you plug your router in.
Jan 31, 2009 | Arris Touchstone 450a (CM450) Modem
Can connect only one computer at a time over westell 327W modem
Try this, go to network connections, right click on your connection, click on properties, where it says this connection uses the following items, scroll down to internet protocol, highlight it then click on properties below it, make sure Obtain IP address automatically is checked. do this on both computers. Let me know if it works. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 15, 2009 | Westell Wirespeed VersaLink...
2wire capacity for wireless connection
yes you can return the linksys.
the following link should help you setup the 2 wire for wireless conneciton.
Dec 03, 2008 | 2wire (1000-000057-000) Modem
Modem reboots when using wireless
Did you try upping your lease time and see if that changes things.
The lease time is the amount of time before a DHCP request a new IP address.
Ususally it get the same, but if it is malfunctioning it can cause problems like this.
Jul 15, 2008 | 2wire (1000-400108-001) Router
Open Questions:
2wire HomePortal 1000 Router Logo
113 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
