Question about Refrigerators
Amp problem to compressor
Ge refrigerator compressor is puting out 1/2 amp it calls fot 7 amps
do i need a new compressor or can this be repaired
  • wayne tolbert
    wayne tolbert Jun 18, 2009
    compressor is running, relay checked out ok at 120 volts
    full of freeon. temp. of freezer is between 40 and 60
    still showing 1/2 amp cant get compressor up to 7 amps
  • 25 Answers
If the compressor is actually running, take the clamp on ammeter and try it on more than one wire going to the compressor. Check your voltage going to the relay. You should read around 120volts at the compressor relay. It may be a bad relay if the compressor is not running.
Posted on Jun 18, 2009
The compressor of my GE PFE 29PSDASS floor model comes on for a few seconds then goes off. The lights remain on. What is wrong?
Refrigerator Repair Help ' Appliance Aid
www.applianceaid.com > ... > Refrigerator Help Section
I heard a sizzling noise inside my freezer section and it looked like something ... Myfridge makes a bang noise when it shuts off; My Frost free fridge will not run at all; Myfridge is making screeching/squeak noises; My GE SxS fridge door has ... an amp meter, each compressor is rated in running amps ( see model/serial tag ...
GE Refrigerator Repair Online Manual ' General Electric ...
www.appliancerepair.net/ge-refrigerator-repair.html
FREE ONLINE GE refrigerator repair manual - Diagnose and troubleshoot ... to know basically how the bloomin' thing works, and then get on with fixing it? ... Chapter 5: GErefrigerator problem: Refrigerator is not cold and compressor is ... Do you have somequestions that you would like to ask a professional GE repairman.
Dec 17, 2015 | GE Refrigerators
What is the width of Kenmore 253.57188600 refrigerator?
Hello Chris;
My name is Peter. I am a retired field service refrigeration technician.
First, The 253 model is an LG. Stay away from LG and Samsung refrigerators. 70% of my service calls were for either LG or Samsung. A common problem; LG would have compressor overload failures caused by the compressor. I would have to change both the overload and the compressor. This was a $650 - $900.00 repair. The Samsung has the best looking unit on the market, with the highest component failure rate. Their televisions are great, but appliances!
Ok, your dimensions.
1.) You need to take a tape measure and measure the space. You need 3/4" on the top and sides for proper air flow. You also require 2-1/2" in the back. Take this information to where you purchase a new unit.
2.) Consider going to a Sears Outlet Store (Scratch & Dent). You save a couple hundred dollars and have a one year warrantee.
3.) Consider a Habit Store for a used appliance.
Ok, What brand do I buy:
1.) If you can afford it: Kitchen Aid, Amanda or Hot Point (Fewest service calls).
2.) GE, Kenmore (Model number 110.---).
I hope I have helped;
Peter
Nov 30, 2015 | Kenmore Side by Side Refrigerator
Clicking sounds when the compressor starts running, then stops. Also, it will make a bang type noise every hour or two.
Shannon ! The noises you are hearing are coming from the compressor and its starter. I believe that you will need a refrigeration technician or a good sparky to check it out. The compressor is trying to start but because either starter is stuffed ( cheap repair ) or compressor stuffed ( not so cheap repair ) it the gets saved by the internal overload. this overload will call down over a period of time and the compressor will try and start again. Destructive cycle! TURN IT OFF. & call a fridgy !
Mar 30, 2014 | GE Refrigerators
The compressor runs for 6 to 7 seconds & shuts off for 1 1/2 to 2 1/2 minutes then runs for 6 to 7 seconds etc. I noticed that the compressor was hot so I cooled with a fan for 1 hour & retried...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 11, 2011 | Refrigerators
Our side be side ge fridge is giving us a problem...power is ok as lights are on and freezer/ice cube & water dispenser is working ok...but regular fridge side is warming up...it has always been set...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Mar 30, 2011 | GE Refrigerators
I have 2004 GE side by side with wather /ice dispenser refrigirator at first dispenser stop warking and now works on and off and no cold
Replace relay and check compressor working. If Compressor works, check with amps for correct amps. If not leak or chock. Call repairman to rectify. Thanks.
Jan 26, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge profile bottom freezer fridge model PDS22MCR. It's making a loud humming noise & the fridge & freezer are getting progressivley warmer. fridge is up to 45 & frezzer 11 in a matter...
The compressor is not starting every time and later it will start again...replace start relay and capacitor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 17, 2010 | GE Refrigerators
GE Profile Refrigerator freezer not working right & ice in refrig
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan runs, compressor tries to start then kicks out on overload.
i am not familar with this model number..
1. are you using the right type of capacitor. you need a "start" capacitor not a run capitor. make sure that capacitor is the proper size.
2. have you tried a hard start kit?
3. is their oil in the new compressor?
4. was the old compressor for r-22 or 410a?
5. is the new compressor for the proper refrigerant?
6. is there refrigerant in the system?
7. is it wired right?
8. is this a heat pump? if so is your reversing valve operationing properly?
9. was the old compressor a mechanical or electrical failure?
if electrical did you install a new filter drier?
10. just because the new compressor is new does not mean it is good
11. do you have the proper voltage?
good luck
hvac teacher
Mar 23, 2009 | Goodman GMS90703BXA Heater
Refrigerator cools as normal. Trips 15 AMP circuit breaker.
a full size refrige has to be on a 20 amp circuit, a 15 amp is just not big enough.. you should also know that this circuit has to be on a 12-2 gauge wire.. I also highly recommend installing a 20 amp HD receptacle
Mar 19, 2009 | Refrigerators
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
