Question about Nokia Cell Phones
Change font size nokia 6680 bigger clock on standby
Hi i want to change the font size of my mobile 1650 ....in display settings i cant c any optn 4 that
Posted on Feb 16, 2010
How do i make txt print bigger on my nokia 6230i?
It is only possible to customize messaging,contacts and web font sizes in the phone.
to customize,goto settings,display,font size.
select font size and select the appropriate category in it and then customize the font size according to your wish..you may select from extra small ,small,normal,large fonts
May 08, 2012 | Nokia 6230i Cellular Phone
How to change fonts in nokia 6680
To change the FONT. Go to> Settings, choose >General then >display then >Personalisation.From there you could choose the font that you want.
Aug 15, 2011 | Nokia Cell Phones
How to change nokia e65 font size
The font size cannot be changed by using any option in mobile but there is a trick to do it .
The following link helps in increasing font size
http://www.dreamstrikes.com/nokia/510-nokia-e65-fonts-too-small-get-new-fonts.html
Jun 24, 2010 | Nokia E63 Cell Phone
How to increase text size when running laptop and % icon does not show in lower right right hand corner of screen
To change the text size you will need to right click on a blank part of the screen/desktop so you get display properties or click start then settings then control panel then display. When you get that window up you can click on the appearance tab along the top. In this window along the lower left is font size. You can increase the size of the font by clicking on the box then selecting the size you want. This will change the size of the font as soon as you click on apply. This only changes menu text sizes.
To change everything overall you want to click on the settings tab then the advanced button lower right. It should come up to the window we want but if not it is under the general tab. Under DPI settings (sometimes will show as text size or font size but all are the same setting) the default is set to 96 try selecting the 120 size. This will increase the size of the text used. You can also select custom and enter any number. You will probably have to reboot the computer after changing this unless you have it in the section below to apply without restarting. Hit apply and reboot if required and your text will now all be bigger. If the text is too much bigger than stock some programs or windows may not look right or the text is not aligned. Thats typical if the text is too big or the window it is in is a fixed size and can't change. If this happen you can try the custom setting to find a bigger size that won't cause problems.
You can also use the visually impaired utilities one of which is a magnifier. That just enlarges an area around the mouse so it isn't quite as easy for daily use.
I'm stumped on the % icon thing. What normally is there is the clock. Unless this is a icon that shows battery charge or something like that? You can usually get these to display again by starting the utility from the start menu - all programs and then look for a setting that says display on toolbar.
Apr 23, 2010 | Toshiba Satellite A135-S2276 Notebook
How do i make the font bigger on my impression phone?
you have to change to a different font type to change the size
You can use this method to change the Font size; from the standby screen; press menu, settings, display & light, font type, select desired font type, then press save.
Dec 11, 2009 | Samsung SGH-A877 Impression Cell Phone
Font
Assuming this is an IBM wheelwriter to change the font size you must install a different print wheel.
DickyO
Jun 15, 2009 | Lexmark Office Equipment & Supplies
Nokia 6680 phone
change the theme on the phone
Dec 23, 2008 | Nokia 6600
Written messages or font to small, how can I enlarge it
I'm sorry to tell you this.. Theres no way to change the size of font in your phone.
Nov 16, 2008 | Nokia 5500 Sport Cellular Phone
Nokia n95 8gb
how can get a good Nokia new model
Jun 20, 2008 | Nokia N95 Cellular Phone
Nokia 6680 charge problem
with respect to your low Nokia 6680's low battery, what you need to do is to charge it while switched off for atleast 12 hours.  It is possible for the phone to have 200+ standby time afterwards but that is if its not used at all. You should also disable the bluetooth, as well as the backup ligthing if switched on as all these can dramatically reduce the life of the battery.
Sep 23, 2007 | Nokia 6680 Handheld
Cell Phones Logo
700 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
