Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
I have Dyson animla and the wand stop working....no bloc anywhere
Looked for blockage and couldn't find any. When you try to use the wand it is hard to get out as if the suction is pulling it back in the holder.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 83 Answers
The hose is getting twisted on the machine and that makes it difficult to pull it out.
1) Pull the wand out as far as you can - if you can pull it out completely, separate it from the hose and apply baby powder to the metal rod. Stretch out the hose and unwind it. In the future, separate the wand and unwind/stretch the hose after use.
2) If you can't pull the wand out all the way, remove the u-bend from the bottom of the machine - turn that plastic screw at the bottom next to the gray hose 45 degrees anti-clockwise and take the u-bend off.
3) Pull the hose out from the bottom (don't pull it out all the way - just enough to release the wand) and pull the wand at the same time - separate the wand from the hose and unwind the gray hose and stretch it out. Rub baby powder on the metal rod of the wand and in future, disconnect the wand from the hose and stretch/unwind the hose after every time you use the wand.
Posted on Jul 30, 2009
My dyson just stopped running while vacuuming with wand
You probably got a blockage in your wand which caused it to overheat and cut out. Check for blockages, use a brush stale down the tube to dislodge anything. Next, check your filters, refer to the tutorials here: Looking after your Dyson.
Nov 27, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
My Dyson dc 18 slim extender wand has NO suction. There is a plastic white cylinder object blocking.
If the floor head has suction and the wand does not, or vice-versa, the white cylinder you are referring to diverts the suction between the floor head and wand. If the flimsy plastic switch used to turn the cylinder is broken, you may need a new under carriage or just set the cylinder to wand or floor manually and use it as a one dimension cleaner. Depending on your ability, perhaps the switch can be purchases and replaced by a DIYer, but the job looks moderately difficult.
Jan 31, 2010 | Dyson DC18 Allergy Bagless Upright Vacuum
My dyson 17 wand does not work. When it is on and you stand it upright it turns off
Hi its Darran at Dyson.
If the suction is good from the base but not from the wand, this would indicate that there is a blockage in the wand handle or hose. To test this, stand the machine upright and release the wand handle. Switch the machine on and test the suction from the top of the wand with your hand. If its poor, remove the wand handle from the hose and try the suction at the top of the hose. If its good here, then there is a blockage in the wand handle.
If the sction from the top of the hose is poor, you can remove the hose to check this for any splits or blockages. If it needs to be replaced, you can buy a replacement online at www.dyson.com.
Alternatively, should you any further help or advice with your Dyson, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson hose looses suction
You have a blockage in the wand. Stand behind the machine and:
1) Remove the u-bend which is located NEXT to the right-hand side wheel, NOT above it. It connects from the bottom of the long gray hose to next to the right-hand side wheel. It is attached to the machine with a rectangular-shaped clip - push the clip and pull the pipe down.
2) Look through the wand if you can (DC07 wand is bent) - if you can't see the ground you have a blockage in either the hose or the wand
3) Remove the hose and separate it from the wand - hold the wand up into the air and look through it - if you can't see light coming through the other end, there is a blockage in the wand. Use a long object like a stick or a metal hanger to remove the blockage.
4) If the wand is clear, stretch the hose out and look for dark spots - those are the blockages. Again use a long object to remove the blockage - be careful not to damage the hose, you don't want to buy a new one.
Jun 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Decreased wand suction
The blockage could be in the wand itself or in the entry duct of the machine. Take the wand off, look through it and if you can't see light coming through the other end, there is something stuck in the wand - take it out with a long object like a metal hanger...if the wand is clear, call the Dyson helpline - they will do a thorough blockage troubleshoot over the phone and clear the blockage.
Jun 20, 2009 | Dyson DC18 all floors Bagless Upright...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
788 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
