Question about Karcher K2.26 Electric Power Washer
Where can I order this part spray wand extension for the Karcher
spray wand extension the end is broke this is for K 3.97 M high pressure washer
  • firehead May 11, 2010
    where in the world are you?
I order a new part
thank you for your help.
Posted on Jun 18, 2009
Why doesn't soap come out of my Karcher 1750g gas pressure washer the soap will not come out thriugh the tube
The wand has a high and low pressure setting. When it is set to high pressure, no soap will come out. This is the way it is designed to work.
Feb 13, 2016 | Garden
Pressure wand is leaking at the out let end, and pump has a small surge when setting at a idle
Sounds like water is leaking past the shutoff valve on the wand. Check your owners manual parts diagram to see if there is a washer or o-ring to replace.
Apr 16, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
The plastic sleeve abo;ve the metal gate valve got striped do you have a metal sleeve to replace? I used this wand on the end of a 10 foot galvanized 1/2" pipe with a metal adapter . do you have a metal...
Hey there
this design seems ok but then they put a plactic adapter on the end...fail. on the inside of that plastic adapter you should be able to use a hex socket to remove from you extension wand. I suspect that the threading is 3/8" or possibly 1/4". You should then be able to match that up at a local pressure washer dealership. It will be 1/4" MPT x 3/4" FGH or 3/8" MPT x 3/4" FGH. Im guessing by looking at a picture of your wand only so still take this adapter out and check to verify the size. If you are having trouble finding the adapter then check here.
Pressure washer parts catalog quick links Pressure Washers High Pressure... Give them a call and they can help. The item numbers you are looking for are
1/4" MPT x 3/4" FGH Item # 3250
3/8" MPT x 3/4" FGH Item #3251
Good luck
Feb 24, 2015 | Orbit Telescoping Gutter Wand Set
Cant remove the wand extension from the spray gun
push together twist and pull apart. hold the trigger in to ensure it's not under pressure. if your having issues still please post a picture
Jan 13, 2013 | Karcher Pressure Washer Gun 91120200...
Briggs and Stratton pressure washer will not spray water. The engine is fine but water does not flow.
The nozzle on the end of the spray wand has a very small hole in it that can be easily clogged by any sort of debris that comes through the water supply.If the nozzle can be removed, just take a pin & clear the hole from the outside & rinse it off. If the nozzle can't be removed, then take the wand apart at the connector in the middle and do the same thing.
Jan 30, 2010 | Briggs & Stratton Pressure Washer...
Cannot get it to uptake the bleach for spraying Dewalt pressure washer 3100 psi
On most pressure washers you wont be able to draw soap/bleach into pump unless you are spraying on low pressure.There is a valve on the inside of inlet hose fitting that closes when high back pressure is sensed.Would it draw bleach into hose when wand tip is removed?
Nov 21, 2009 | Dewalt Garden
Where can I purchase oil rings that go into the spray wand of a McCulloch FHH18A electric power washer.
I assume you mean the rubber O rings inside the wand. I had to replace mine as well. I had to visit several plumbing supply stores to find one that fit. I ended up taking the end of the wand with me so I could make sure the O ring fit. The ring you are after is a number 5, but you need to make sure it is thick enough to make a good seal.
Sep 10, 2009 | McCulloch FHH18A Electric Pressure Washer
Add fluid to tank but it never goes down no matter how long I spray, is it a product fluke?
Your pressure washer has a knob on the front that lets you choose between tank 1 or tank 2. Tank 1 is the larger of the two tanks. Make sure you have the knob set to position 1. Also, you will find that when you have the wand set to high pressure, the tank will not work as well. When you want to spray soap, spray with the low pressure setting. You can set the pressure to low by pulling out the nozzle on the front of the wand. Pushing it back in is high pressure.
Aug 09, 2009 | McCulloch FHH18A Electric Pressure Washer
Whe using the honda 3000 psi power washer, I've
Are you putting the soap nozzle on the end? Either that or depending on what type of nozzle you have, some times you pull out or push in the nozzle to switch it to soap.
There has to be no pressure to draw the soap, so you either have to put in the soap nozzle in, or if it has an adjustable end, set it to soap by pushing or pulling.
You cannot spray high pressure with soap unless your unit is equipped with another siphon hose for pressure soap.
May 03, 2009 | Garden
I need a McCulloch FH140A pressure washer spray nozzle
you will have to replace the wand which you can purchase from a reputable hardware store
Apr 08, 2009 | McCulloch 1400 Psi Electric Pressure...
Karcher K2.26 Electric Power Washer Logo
219 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
