Question about Whirlpool RF364 Electric Kitchen Range
Burners and oven wont work
My electric range ,the lights come on but the oven and burners wont work and i used this morning fine
    President:
  • 512 Answers
Sounds like the thermal fuse is burned out. If you look on back of stove or pull out drawer you should find wiring diagram. Look for thermal fuse. With unit unpluged test with a tester. If found to be bad replace. This is probably you problem.
Posted on Jun 17, 2009
Burners wont work any more
Good Morning Fern mullen, I appreciate your post!
Based off what you have described your burners are no longer working on your Frigidaire range. This could be an issue with your control panel or the switch. I would recommend performing a reset on your range and you can do that by disconnecting power from the range for at least ten minutes. If that does not help correct your issue I would suggest having a technician out to your home for a proper diagnosis and repair. Best of luck! -Matt
Feb 28, 2015 | Frigidaire FGEF306TMF 30" Freestanding...
Oven wont work everything else is fine
As your oven is electric there is a heating element in the oven, have a look in the oven to find it and check the little plug in caps on the end to make sure they are not loose. If they,re ok check the switch on the front panel sometimes the knob comes loose on the spindle if that's all ok it may be the switch has failed. Good luck.
Jun 16, 2014 | GE Profile JGSP44 Dual Fuel (Electric and...
I have a HD2515U Stainless Steel Dual Fuel stove (hooked up to propane, not natural gas). Oven still works, but burners wont ignite. It has electric ignitors. I've followed all the steps to make sure...
The wiring harness for the burners sound like is shot! I would think about buying a new one! have You tried to light the burners with a lighter or match to see if they will ignite? If so,replace the wiring harness, over time they go bad and short out! If You Can use lighter to ignite burner I would use the long nosed ones like You start charcoal with till The new wiring harness arrives! You will save the hair on Your arm that way! LOL! Good Luck!
Jul 14, 2017 | Siemens HD2515U Stainless Steel Dual Fuel...
Viking model vdsc4874gss small oven works fine large oven element on bottom only gets hot in cleaniong mode, fan comes on when dial is turned to convection but no heat power is on light works
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Oct 18, 2010 | Viking 48" 6 Burner, Grill Professional...
Burners abruptly stooped working on top of the stove
check electrical panel of your house and make sure both breakers are in the on possition ..
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
Oven and coil burners work one time then the next time neither one warms up, try again later and it works again. started last week when the oven preheated put in food to cook and half hour later noticed...
If this is an electric range, it sounds like you are not geting 220v all the time. check were your cord or house power hooks up to range. You may find one side of the 220 line burnt. Shut off power and repair conections. or call a qulified tech.
Nov 22, 2009 | Ovens
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Auto light wont fo off
good day,
hope this link below will solve your problem.
ovens
Aug 15, 2008 | Rangemaster 110 (Gas) Kitchen Range
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
Whirlpool RF364 Electric Kitchen Range Logo
404 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
