Question about Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher still has dirty water in the bottom when finished. The dishes are also still covered in a soapy/dirty layer?Is this my pump or something?
    Problem Solver:
  • 7 Answers
You need to top up with salt and rinse aid.
Posted on Jun 17, 2009
  • 126 Answers
Have you recently replaced disposal,if so knock out plug.If not you will need to remove sump cover and filter ,on the left hand side of sump area you'll find t-20 screw remove and pull cover off you will be able to see pump impeller .make sure you can turn impeller and remove any debris,usually something is stopping impeller from turning.
Dishwasher not cleaning dishes
DISHWASHER NOT CLEANING WELL??
Here are 5 common reasons why not.
Here are Improper Water Temperature
I can tell you from personal experience that water temperature has a direct impact on how well your family's dishwasher operates. If the water entering your dishwasher is not hot enough, your dishes are likely to come out coated with grease and dish detergent residue. As such, you will want to make sure that the temperature of the water inside your dishwasher is somewhere between the range of 120 degrees Fahrenheit and 140 degrees Fahrenheit. If it's not it could be a faulty heating element.
Dirty Pump
Based on my experience, a dirty dishwasher pump will also cause your dishwasher to produce less than stellar results. Therefore, you may want to consider cleaning your dishwasher's pump every six months. In many instances, it is an easy task to complete. In order to clean your dishwasher's pump, you'll most likely have to remove the dishwasher's spray arms. Once the spray arms are removed, you'll want to clean and inspect the pump's impellers, blades and pump guard. I should also mention that there are appliance companies that sell dishwasher pump repair kits should you notice that a part needs to be replaced. A basic dishwasher pump repair kit will tend to cost you $20 to $60 depending on your dishwasher's unique needs.
Dirty Spray Arm
Dirty spray arms may also be to blame. After all, if the spray arms' holes are clogged, the hot water won't be able to reach the dishes properly. A dishwasher's spray arms are very simple to clean. In order to clean them, you will need an old toothbrush and a bread twist tie that has been stripped of its paper. Use the toothbrush's bristles and the wire from the bread twist tie to unclog all the holes.
Broken Dish Detergent Dispenser
A broken dish detergent dispenser is another likely culprit when it comes to dish cleanliness problems. Sometimes the dish detergent dispenser's door will not open or shut properly, which prevents the dishes from getting nice and soapy. The good news is that most dish detergent dispenser problems may be solved relatively inexpensively. The cost of a replacement dish detergent dispenser will vary based on the make and model of your dishwasher. There are also instructional videos online that will help you with the installation of your dishwasher's new detergent dispenser.
Dirty Filter
A filter has an impact on a dishwasher's effectiveness as well. Hence, you will want to inspect your dishwasher's filter for obstructions. The location and type of filter will vary based on your dishwasher's make and model. I would recommend that you check out your dishwasher's operator's manual. It should contain instructions on how to clean your particular unit's filter as well as where you can order a replacement part if need be.
Dec 16, 2013 | Dishwashers
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    I have a ADG450 about 7 years old, the problem is there is dirty water left at the bottom of the dishwasher after finishing the cycle and the dishes look as if they have had the final rinse in the dirty...
    check the pipe leading from the dishwasher to the outlet, maybe under sink. this needs to be raise up as water will flow back into washer. Had this problem myself, felt foolish when the repair man just tied it up and left. !
    Jan 03, 2011 | Whirlpool ADG450 Slim-Line Built-in...
    It' no longer cleaning my dishes
    hello,
    If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
    To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
    thanks.
    Oct 23, 2010 | Dishwashers
    Dishes are still dirty at the end of the cycle
    hello,
    hope this help?
    thanks.
    Oct 23, 2010 | Kenmore Dishwashers
    My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
    Check whether the top rack spray arm main hose sits firmly into the
    machine. If there is a leak in this area water pressure may not develop.
    Also check the water pump in the machine!
    Oct 01, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
    Soapy water standing in bottom not rinsing soap off dishes
    It sounds as if it is not draining. Try to trace the drain line under the sink. Usually it goes into a disposall. The port where it connects to the disposall may be clogged. Another thought. If you had the disposall replaced recently they may not have taken the knock out plug out which would give the drain water no where to go.
    Apr 09, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
    Dishes are dirty when finished water still in bottom of machine
    you have a drian and /or pump and motor you didnt give the brand . It would help. call 704-819-6557 for free tech support and parts.
    Mar 14, 2009 | Dishwashers
    GE Triton XL, Dishwasher, while washing dishes in the sink
    Ho could be a blockage in the dishwaser pump, is the drain plug clear .............
    Jan 17, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
    Dishwasher not cleaning dishes. Casade cleaner not disolved.???
    Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
    Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
    Bosch 24 in. SHU43 Built-in Dishwasher Logo
    581 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
